VSL - 6880 using built in chassis ports
GRANT3779
I have a 2 x 6880x with only the built in 16 ports on the chassis.
If I create the VSL link between these using 2 ports from each chassis, does this render the other ports to a disabled state that cannot be used? Or does this info refer only to ports on an additional switching module if added to chassis?
I have been reading this info in the following doc.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/15-0SY/configuration/guide/15_0_sy_swcg/virtual_switching_systems.html
Rolf Fischer
Level 9
Level 9
I don't know the answer (voted "I have this problem too") but I found this discussion which might help a bit: https://supportforums.cisco.com/discussion/12465006/6880-vss-c6880-x-16p10g
Hi Rolf,
Thanks, that has helped and interesting read!
So reading this, each port groups can only have 8 ports? Are the port groups something that are preconfigured/decided or can you move ports between port groups?
