VSS configuration for Cisco 4500 Series switches
night143r
Hi Community,
I have been assigned task to configure 2x Cisco 4500 Series switches
Both switches are of same model and shall have same iOS.
Need to know physical topology of both switches , How to connect cables, and the configuration
Thanks in Advance, as I get a lot of help from this community in my previous issues that I faced in job
6 Replies 6
Leo Laohoo
What is the supervisor card?
Configuring a VSS
Leo I don't know yet as We haven't received switches
balaji.bandi
VSS Rule - make sure both the hardware same, and running same IOS Code.
follow below URL : bit chinese, but you can understand :
https://community.cisco.com/t5/%E7%BD%91%E7%BB%9C%E6%96%87%E6%A1%A3/vss-configuration-for-cisco-4500-series-switches/ta-p/4381452
BB
I know both switches are of same model and I will get iOS from team
Rest I ll follow guide received from this community
Thank you ALL for the help
Hello Can you please tell me what would be the physical topology/connections with switches
Both Switches are powered on  (Same hardware , same iOS)
Then I need insert SFPs in both switches and connect ethernet cables  with switch 1 and 2
and thats it
Right ?
balaji.bandi
yes correct, one of them will reload once they form the VSS.
BB
