Showing results forĀ
Search instead forĀ
Did you mean:Ā
VSS - Enable the NSF-SSO feature for the IP Routing protocols? RIP?
wuyuke1982
Hi All
just a quick question about VSS, from the VSS configuration guide below.
http://www.cisco.com/en/US/products/ps9336/products_tech_note09186a0080a7c74c.shtml#mig_path
check 11. c.
"Enable the NSF-SSO feature for the IP Routing  protocols used. VSS simplifies the routing configuration, so some of the  network statements are no longer required. "
the sample is for ospf, I check the other documents. they have samples about eigrp, ospf and BGP, but how about rip?
is rip nsf-aware? what could we do if we implement VSS in the network, and only routing protocol we used is rip?
just skip the step? any experience sharing is welcome.
thanks
Yuke
wuyuke1982
rip is not NSF aware, confirmed by my colleague. need to configure ospf, eigrp or BGP for the VSS sup fail over.
