VSS etherchannel problem
suthomas1
Level 6
Level 6
We have two 6500 & are trying to create VSS for this.
Below are the configurations on both switches;
Switch1:-
switch virtual domain 100
switch mode virtual
switch 1 priority 110
interface Port-channel1
description VSL to Switch2
no switchport
no ip address
no platform qos channel-consistency
switch virtual link 1
interface TenGigabitEthernet1/5/4
no switchport
no ip address
no cdp enable
channel-group 1 mode on
interface TenGigabitEthernet1/5/5
no switchport
no ip address
no cdp enable
sh switch virtual
Switch mode                  : Virtual Switch
Virtual switch domain number : 100
Local switch number          : 1
Local switch operational role: Virtual Switch Active
sh switch virtual link port-channel
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      N - not in use, no aggregation
        f - failed to allocate aggregator
        M - not in use, no aggregation due to minimum links not met
        m - not in use, port not aggregated due to minimum links not met
        u - unsuitable for bundling
        d - default port
        w - waiting to be aggregated
Group  Port-channel  Protocol    Ports
1      Po1(RD)          -        Te1/5/4(D)     Te1/5/5(D)
Switch2:-
switch mode virtual
interface Port-channel2
description VSL to switch2
no switchport
no ip address
switch virtual link 2
interface TenGigabitEthernet2/5/4
no switchport
no ip address
no cdp enable
channel-group 2 mode on
interface TenGigabitEthernet2/5/5
no switchport
no ip address
no cdp enable
Te5/4 on switch 1 is physically connected to Te5/4 on switch2.
Appreciate all help.
Once VSS is working the individual ports line te3/4 would be 1/3/4 1 for switch 1 3 for blade 3 and 4 is the port.
also on switch 2 the same port will be 2/3/4 2 for switch 2 3 for blade 3 and 4 is the port.
Also, follow the config guide to make sure the VSS working:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/vss.html
suthomas1
Level 6
Level 6
We are looking to do VSS with only one link between both switches.
is it different from the above?
There is no difference.  You can use one link or 2 links, but for redundancy it is always a good idea to use 2 links.  Also, you don't need this command on either switches:
Also, you did not explain the issue you have.
sorry, i guess forgot to type the complete thing.
We are trying to run VSS on two 6500's with single link between them.
i have used the configuration above, but the VSS doesn't come up.
doing a sh virtual switch only shows the current switch ; i.e switch 1
If we are using single link , on each individual port like te3/4 how would the configuration look like, as i see the switch virtual link command is used under Port channel.
please help in this.
