Nexus 5548 - ipv6 interface
Is it possible at nexus 5548 with daughter card to assign ipv6 address to interface?
I have gone thru lot's od docs cisco says on tech doc:
• IPv6 Routing Protocols: Static, Open Shortest Path First Version 3 (OPFv3), Border Gateway Protocol (BGPv6), Enhanced Interior Gateway Routing Protocol (EIGRPv6)
• IPv6 VRF Lite
So I am assuming is supporting IPv6 routing.
command line:
NEXUS-1(config-if)# ipv6 add?
% Invalid command at '^' marker.
NEXUS-1(config-if)# ipv6 ?
  port  Port policy
I was looking for feature to turn on but doesn't looks there is one.
Doesn't seem that I can turn it on by ipv6 unicast-routing.
Marcin,
Nope ipv6 is not supported on 5.1(3)N2(1) i.
Were as it is supported on 5.2 release.
Feature History for IPv6
Table 3-5 lists the release history for this feature.
Table 3-5     Feature History for IPv6
Feature Name
Releases
Feature Information
IPv6
5.2(1)
This feature was introduced.
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/unicast/521_N11/l3_ipv6.html#wp1200855
Inayath
Please rate and mark the post as answered so others can benefit from it.
5 Replies 5
sean_evershed
Level 7
Level 7
It might be something to do with your version of NX-OS.
Don't forget to rate all helpful posts.
https://supportforums.cisco.com/thread/2077565
My NX-OS is 5.1(3)N2(1) is that one supporting ipv6?
Is quite weird that nexus doesn’t support ipv6 where there is no many ipv4 left.
CISCO should really sort that out, we have spent over £50k for switches and we are not able to do dual stack ;(
Marcin,
Feature Name
Releases
Feature Information
IPv6
5.2(1)
Inayath
Does it mean that we have to buy new NX OS update for brand new switches?
We have received those switches with this software yesterday.
Or do I need to buy ASR to do IPv6 routing?
thanks
InayathUlla Sharieff
Marcin,
Just go ahed and upgrade the firmware.
Inayath
