VSS Interface question
cowetacoit
I'm planning a maintenance window to deploy VSS on a pair of 4506-Es. I'm in the process of building the configuration file since the naming convention changes to "interface-type switch-number/slot/port".
My question is after the VSS pair is formed.....what does the second switch's interface naming look like? Since they are both 4506-Es i'm wondering if the supervisor will still be considered a Slot.
example:
1/1/x     Supervisor
1/2/x     Linecard
1/3/x     Linecard
1/4/x     Linecard
1/5/x     Linecard
1/6/x     Linecard
2/1/x     Supervisor
2/2/x     Linecard
2/3/x     Linecard
3/4/x     Linecard
3/5/x     Linecard
3/6/x     Linecard
Jon Marshall
Yes, the supervisor port(s) on the second switch will be seen as 2/1/x. They have to be to be distinguishable from the other switch's supervisor port(s).
Jon
Reza Sharifi
As Jon also noted, the naming convention will change.  So, for example
switch 1, blade 4 and port 28 will look like this:
1/4/28
the same port for the second switch will be
2/4/28
same for Sups
primary sup 1/5/4
back up sup 2/5/4
and so on...
there is no 3/x/x or 4/x/x, because for VSS the max is 2 switches.
