VSS is experiencing High CPU and a module reload
plgingembre
I've deployed VSS on a client site and I'm experiencing a high cpu state since we've loaded servers and switches on it.
Furthermore, we've encountered another problem today: the reload of one module on the standby switch...
Sep 13 18:42:35.368 CET: %OIR-SW2_SPSTBY-3-PWRCYCLE: Card in module 1, is being power-cycled off (Reset - Module Reloaded During Download)
Sep 13 18:42:35.368 CET: %C6KPWR-SW2_SPSTBY-4-DISABLED: power to module in slot 1 set off (Reset - Module Reloaded During Download)
Sep 13 18:46:46.472 CET: %C6KPWR-SW2_SPSTBY-4-DISABLED: power to module in slot 1 set off (Module Failed SCP dnld)
00:00:12: %SYS-CFC1-5-RESTART: System restarted --
Cisco IOS Software, c6lc2 Software (c6lc2-SP-VM), Version 12.2(33)SXH3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 25-Jul-08 03:56 by prod_rel_team
I join a show proc cpu history in order to illustrate what I'm writing.
If you have any idea...
Thanks for your help.
Pierre-Louis
Giuseppe Larosa
Hello Pierre-Louis,
about the module:
The virtual switching system requires 67xx series switching modules.
The virtual switching system does not support classic, CEF256 or dCEF256 switching modules. In virtual switch mode, unsupported switching modules remain powered off.
So verify that in your chassis there are only linecards of this type.
sh module provides this info
About high CPU usage.
Issue a
sh proc cpu sorted 1min
some times in different time intervals and post the output here.
Hope to help
Giuseppe
Hi Giuseppe,
As you can imagine, the only line card not powered on inserted in VSS is a FWM... The rest of the cards are exclusively CEF720 modules.
My problem is that one module has been powered off without any reason. I don't understand why and my client is a bit afraid about that, of course !
I will put you the show proc cpu sorted as soon as I get it.
Pierre-Louis
