VSS + MACsec
gilles.risch
Visitor
Hi all,
The current setup:
We have 4 Cisco Catalyst 4500X switches in two different buildings. In each building we have a VSS, both VSSes are interconnected by a PAgP port-channel composed of link 1 and link 2.
+-------------------+    VSL   +-------------------+
| Switch 1: (4500X) |==========| Switch 2: (4500X) |
          ¦ Link 1                       ¦ Link 2
| Switch 3: (4500X) |==========| Switch 4: (4500X) |
We would link to use MACsec encryption on between both VSSes in manual mode, without authentication server. Is that possible and which firmware version is needed for the setup?
Has someone a comparable installation, what are the pitfalls that one has to pay attention?
Gilles
gilles.risch
Visitor
some more information:
  • Link 1 and 2 are point to point dark fibers
  • The switches are running 3.5.x
Gilles
alex.net
Frequent Visitor
Frequent Visitor
I have a really similar setup...but it's not easy to find documentation.
Is it necessary an additional module?
By the way, 3.5.x is fine
From the Release notes:
MACSec Encryption on Cisco Catalyst 4500-X
- IEEE 802.1ae MACSec Layer 2 encryption
- IEEE 802.1ae MACSec encryption on user-facing ports
- IEEE 802.1ae MACSec encryption between switch-to-switch links using Cisco Security Association
A.
