I'm currently in the porosses of migrating two 6509 switches from Standalone to VSS but i'm facing some strange issues. As soon as i did the converstion the interfaces of switch 2 (Secondary) are defaulted. What I did then was I manaully edited the startup config with the interfaces of switch two in format 2/x/x but when i'm reloading (first starting up the primary then the secondary) the secondary config isn't being populated.
Under module provision of switch 2 the modules are defined correctly.
module provision switch 2
slot 1 slot-type 156 port-type 31 number 24 virtual-slot 33
slot 3 slot-type 147 port-type 61 number 48 virtual-slot 35
slot 5 slot-type 254 port-type 31 number 2 port-type 61 number 1 port-type 60 number 2 virtual-slot 37
slot 7 slot-type 147 port-type 61 number 48 virtual-slot 39
slot 8 slot-type 147 port-type 61 number 48 virtual-slot 40
slot 9 slot-type 147 port-type 61 number 48 virtual-slot 41
What could be the issues.
Etienne
