10-08-2020 07:25 AM - edited 10-08-2020 07:27 AM
Hi Networkers
i've weird situation on VSS 6509 with IGMP-queries sourced by single SVI coming back via VSL from standby VSS-member. Gonfiguration:
interface Vlan700
ip dhcp relay information trusted
ip address 10.70.0.1 255.255.255.0
ip helper-address 10.0.43.100
ip helper-address 10.0.100.30
ip pim sparse-mode
ip igmp snooping querier query-interval 5000
LOGs:
Oct 8 13:56:11: %IGMP-3-QUERY_INT_MISMATCH: Received a non-matching query interval 5, from querier address 10.70.0.1
Oct 8 13:57:11: %IGMP-3-QUERY_INT_MISMATCH: Received a non-matching query interval 5, from querier address 10.70.0.1
(& so on so on so on)
i've been trying to catch the path packets get to come back to switch with number of tools but i was only able to catch it with netdr. decoded src_intf points on 21/Switch (switch itself), 37/Te2/5/4,Te2/5/5 (VSL comprising intfs on standby VSS-member).
Any idea how to t/s further w/o TAC involvement?
10-08-2020 08:26 AM
- Check if this thread contains useful hints :
M.
10-08-2020 08:51 AM - edited 10-08-2020 08:52 AM
Do you need IGMP on your network ? what is VLAN 700 in your network ?
check one of my thread to resolve
if this not working please post more information,
10-08-2020 09:04 AM
@balaji.bandi & @marce1000
thanks Guys but references r useless in this case. In my env i've managed to t/s referred cases in few minutes by capturing data coming to the switch, isolating sources & filtering it on access layer.
In current case VSS is itself source of IGMP queries & it made me to stuck on how to find the reason why VSS receives its own queries via VSL %O.
Seems like TAC is unavoidable...
