VSS with Line cards 6148 Question
ajinc
Dears,
I am facing a problem with 6509-E in VSS enviorment. After the VSS configurations the line cards are not coming up.
Supervisior : VS-S720-10G Line cards: WS-X6148A-GE-TX , It says unsupported modules found in slots.
I have seen some docs says these line crds may not be supported, Does anyone have any Idea/ Docs on this ? Any workarounds to overcome this situation ??
Thanks in advance..
Aji N C
francisco_1
Level 7
Level 7
Someone has posted same question.
please see for answer to your question https://supportforums.cisco.com/message/3037087#3037087.
You need to have the right supported hardware for VSS. No workaround
Francisco
Giuseppe Larosa
Hello Aij,
they are not supported for sure, only 67xx series linecards can be used on VSS
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/vss.html#wp1053927
Edit:
Francisco, you are right it is exactly the same question.
Hope to help
Giuseppe
