vtp client not updated
network
Community Member
Hiiii
vtp client is not updated from vtp server inspite of having same domain name and lower revision configuration no. of client. could not understand what is the issue...
ur suggestion will be highly appreciated..
regards,
amit
10 Replies 10
bvsnarayana03
Level 10
Level 10
Hello, is the trunk UP? Also chk if there is a password configured for vtp domain. Assuming the other switch is configured as client & not transparent.
Hiii, yes the trunk is on and there is no password configured and other switch is in server name.its only one switch in client mode which is not updated by server others are getting updated..any thoughts
Try stripping out the vtp domain name and re inputting it.
already tried this resulting the config revision no. to 0.bt still its not updating
Try making a new vlan on the server and deleting it to generate a couple of updates, and see if that makes any difference.
Martin
can we see the show vtp status on both switches?
sure for ur convinience i am posting the output of show vtp staus command for server n client switches.
for server switch-
VTP Version : 2
Configuration Revision : 16
Maximum VLANs supported locally : 1005
Number of existing VLANs : 16
VTP Operating Mode : Server
VTP Domain Name : CORE
VTP Pruning Mode : Disabled
VTP V2 Mode : Disabled
VTP Traps Generation : Disabled
MD5 digest : 0xA2 0x49 0x7F 0xEB 0x52 0xF5 0x4F 0xE0
Configuration last modified by 10.101.43.1 at 3-2-93 21:31:25
for client switch-
sh vtp status
VTP Version : 2
Maximum VLANs supported locally : 128
Number of existing VLANs : 15
VTP Operating Mode : Client
MD5 digest : 0xFA 0x3F 0x7B 0xB9 0x05 0x94 0xD8 0xBB
Configuration last modified by 10.101.43.5 at 4-13-93 02:22:38
This looks ok. have you run a debug to chk vtp synchronisation?
can u plz suggest the appropriate commands to do this...
not sure, but try this...
debug sw-vlan vtp
