VTP issue
hamza-ali
Hi All, i have an vtp server switch i want that my client switch get an vlan from server switch..but client switch unable to get an vlans from server...
please find server switch trunk config:
description "3850_Switch_VTP"
switchport mode trunk
end
please find client switch trunk config: (Configuration not excepted on cisco switch  interface: switchport trunk encapsulation dot1q)
end
5 Replies 5
pieterh
Start with " show CDP neighbor"
The output shows the configured vtp domain, and management vlan  wich should match both ends
Next check " show vtp status"
If different,  configure vtp domain. vtp version. vtp password. Then
Cristian Matei
   Please provide following output of following commands from both switches: "show vlan brief" , "show vtp status" , "show vtp password" , "show vtp interface" , "show vtp devices" , "show interfaces trunk" , "show cdp neighbors".
   Are switches directly connected or are there other intermediate switches in the path?
Cristian.
Hello
make sure the switches are running the same vtp domain/version
disable dynamic pruning (caution if on live production network)
your Trks are allowing all vlans
delete /recreate a vlan and then check the vtp D/B  of the switches thereafter
Note:
mismatched vtp domains:
defined domain1 & null domain = vtp propagation should work
defined donain1 & defined domain2 = vtp propagation WONT work
Kind Regards
Paul
balaji.bandi
i take this as 3850 as VTP server, what model of switch is Client ?
can you post more information on client and server side configuration in related to VTP
good reference if you like to refer :
https://www.cisco.com/c/en/us/support/docs/lan-switching/vtp/98154-conf-vlan.html#toc-hId-2098124139
BB
pieterh
>>> (Configuration not acccepted on cisco switch  interface: switchport trunk encapsulation dot1q) <<<
this does not need to be a problem, depends on switch model and IOS version
some recent models support encapsulation dot1q only  (and no encapsulation ISL anymore)
so those switches do not need (c.q. do not allow ) for this in the configuration
of course "switchport mode trunk" is needed on both sides of the link
