VTP Loop Prevention
Ali Hazim
Hi All,
In a Redundant Topology, How Does VTP Avoid Loops When Sending Its Summary Advertisement
luis_cordova
Hi @Ali Hazim ,
The VTP packets are carried by vlan 1.
All Cisco switches use PVST, which means that the switches run to separate STP for each VLAN.
Actually, it is STP that avoids loops in traffic control packets, such as VTP.
You can check more details in this link:
https://www.cisco.com/c/en/us/support/docs/lan-switching/vtp/98155-tshoot-vlan.html#topic12
Remember to mark the correct answers as solved, since that helps other users with similar doubts
balaji.bandi
Server—In VTP server mode, you can create, modify, and delete VLANs and specify other configuration parameters, such as VTP version and VTP pruning, for the entire VTP domain. VTP servers advertise their VLAN configuration to other switches in the same VTP domain and synchronize their VLAN configuration with other switches based on advertisements received over trunk links. VTP server is the default mode.
what kind of Loop we are discussing here ? Loops are on L2 how  you desing STP in the network.?
Configuring VTP reference guide :
https://www.cisco.com/c/en/us/support/docs/lan-switching/vtp/98154-conf-vlan.html
BB
