VTP pruning question
mahesh18
Level 7
Level 7
Hi Everyone,
Need to confirm topology below
i have layer 3 switch connected to layer 2.
Layer 3 is VTP server mode and has vlan 20.
Layer 2 switch also has vlan 20 and single trunk connection.
I enabled VTP pruning on server switch.
Layer 2 switch has only 1 port up which is trunk port to layer 3.
When i enable pruning VTP server switch shows
Port        Vlans in spanning tree forwarding state and not pruned
Fa0/12      1
It does not show vlan 20 here.
As trunk should carry all the vlans
Layer 3 switch port fa0/12 config
interface FastEthernet0/12
description Dynamic Desirable Trunk to 2950B
switchport trunk allowed vlan 1,20
switchport mode dynamic desirable
speed 100
duplex full
Is this default behaviour or not ?
MAhesh
3 Accepted Solutions
Giuseppe Larosa
Hello Mahesh,
if there is no access port in Vlan 20 in up/up state on L2 switch VTP pruning is triggered and vlan 20 is actually pruned on the trunk link.
This means that unknown unicast, broadcast and multicast traffic in Vlan 20 is not sent out of the trunk port from the L3 switch side, as L2 switch has signalled via VTP that it has no users in vlan 20. And this is the VTP pruning feature in action.
However, STP is still running for Vlan 20 ( if you are using the default PVST+ STP mode).
When an user in vlan 20 is added to L2 switch the vlan 20 will be listed under ithe " STP forwarding state and not pruned" category.
At this point traffic to the new user and unknown unicast, multicast and broadcast traffic for Vlan 20 will be sent out the trunk from L3 switch side to L2 switch.
Hope to help
Giuseppe
Kyle McKay
Level 7
Level 7
What you need to remember with VTP pruning is that the VLAN will only traverse links that it needs to. Just because you have configured a trunk to allow that VLAN does not mean it will be actively forwarding on the link anymore.
If you have users on VLAN 20 (access ports) on the L2 switch I would expect that VLAN to be running on the trunk.
Hello Mahesh,
the note about VTP pruning not affecting STP is very important for scalability:
relying on VTP pruning allows to minimize   flooding of traffic over the trunk links, but it does not save on the number of STP instances running on the device.
As you have seen STP is still running on both switches for vlan 20 not only on VTP server but also on VTP client.
There are some low end platforms that have limitations on the number of STP instances that can run on the box, and only the use of manual list of Vlans (switchport trunk allowed vlan )  on trunks allow to minimize the number of STP instances not VTP pruning.
Hope to help
Giuseppe
5 Replies 5
Giuseppe Larosa
Hello Mahesh,
Hope to help
Giuseppe
Hi Giuseppe,
I checked on Server switch
sh spanning-tree vlan 20
VLAN0020
  Spanning tree enabled protocol rstp
  Root ID    Priority    24596
             Address     000d.28bc.fd80
             This bridge is the root
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    24596  (priority 24576 sys-id-ext 20)
             Aging Time 300
Interface           Role Sts Cost      Prio.Nbr Type
Fa0/12              Desg FWD 19        128.12   P2p
So this shows that STP is still running on VTP server switch right????
Also i plugged pc to layer 2 switch then the sh int trunk on layer 3 switch shows
Fa0/12      1,20
thanks
MAhesh
Hello Mahesh,
Hope to help
Giuseppe
Hi Giuseppe & Kyle,
Many thanks for detaied reply back.
Now my concepts regarding Pruning are mich more  clear.
Best regards
MAhesh
Kyle McKay
Level 7
Level 7
