03-05-2019 06:59 AM
Good Day,
I have migrated two of my core switches. new cores are 9407 whereas, the access switches are a mixture of 2960 and 3850. All trunks are up and working but VTP version number is not getting matched. Since cores are the servers and access switches are the clients.
I have defaulted the interfaces on both sides one by one but the issue is not getting eliminated. Any suggestion as per experience, please?
Thanks for the support.
03-05-2019 07:11 AM
03-05-2019 07:31 AM - edited 03-05-2019 07:32 AM
Can you post below information :
Show vtp Status and show vtp statistics (both server and client switches)
Also see sh vlan brief ( anything suspended) ? post the same output here
03-06-2019 01:26 AM
Good Day,
I shifted the mode to transparent from server/client....
VTP Version capable : 1 to 3
VTP version running : 1
VTP Domain Name : RHH
VTP Pruning Mode : Disabled
VTP Traps Generation : Enabled
Device ID : d4c9.3c6e.8dc0
Configuration last modified by 10.1.5.2 at 3-5-19 12:17:33
Feature VLAN:
VTP Operating Mode : Transparent
Maximum VLANs supported locally : 1005
Number of existing VLANs : 34
Configuration Revision : 0
MD5 digest : 0x64 0xA6 0xE4 0x3D 0x6D 0x08 0x18 0x8A
0x29 0xE0 0x38 0xA8 0xCD 0xCF 0x08 0x1C
*** MD5 digest checksum mismatch on trunk: Po12 ***
Device ID : d4c9.3c2a.6b00
Configuration last modified by 10.1.5.3 at 3-5-19 12:17:33
Feature VLAN:
MD5 digest : 0x1F 0xC0 0x2C 0x05 0xD5 0x69 0x67 0x69
0xFD 0x53 0x7D 0xA3 0x44 0x9E 0x6E 0xAA
Sw1 (Source)
VTP version running : 2
VTP Domain Name : hospital
VTP Pruning Mode : Enabled
Device ID : 78da.6ee7.9200
Configuration last modified by 10.1.5.13 at 11-14-16 10:57:31
Feature VLAN:
Number of existing VLANs : 38
MD5 digest : 0xA4 0xE9 0x65 0xA6 0xD7 0xF0 0x9F 0x0D
0xFF 0x47 0xC8 0x07 0x2A 0xBB 0xBC 0x40
SW2 (Destination)
Device ID : 6073.5c91.ac80
Configuration last modified by 10.1.5.10 at 11-14-16 10:57:31
Feature VLAN:
MD5 digest : 0xB4 0xD7 0x16 0x7E 0x96 0x5E 0xA7 0x43
0xD1 0x20 0xE5 0xAA 0x36 0x5E 0x64 0x73
I created one test vlan on all 4 switches....vl 100 from cores to SW1 and SW2 they can ping each other ..but SW1 and SW2 SVIs (vl100) are not pinging to each other.....
please advice...
03-06-2019 05:08 AM - edited 03-06-2019 12:33 PM
Hello
FYI - VTP version 1 and VTP version 2 are not applicable to work with each other on switches in the same VTP domain.
Looks like from your post all the switches support vtp 2 so suggest to make them all vtp ver 2 in the same domain and test again
03-06-2019 06:28 AM
below clear giving you the logs to take action, so change vtp version to 2 and if you looking to be client, make it from transparent to vtp client to fix the issue. and advise.
Feature VLAN:
Feature VLAN:
03-06-2019 06:40 AM
VTP version running : 1 < change from 1 to 2
Feature VLAN:
*** MD5 digest checksum mismatch on trunk: Po12 *** << remove authentication or set the same for all switches
Feature VLAN:
Sw1 (Source)
VTP Domain Name : hospital < this domain is different from other first two domains.
Feature VLAN:
SW2 (Destination)
VTP Domain Name : hospital < this domain is different from other first three domains.
Feature VLAN:
Thanks in advance.
