VTP Trunk
edw
Level 5
Level 5
C2821 with a Switchcard - I have got to get VTP flowwing between them - the card is known as GI1/0.
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet1/0
no ip address
interface GigabitEthernet1/0.1
no ip address
encapsulation dot1Q 1 native
ip address 10.1.1.254 255.255.255.0
no snmp trap link-status
interface GigabitEthernet1/0.2
encapsulation dot1Q 2
ip address 10.2.1.254 255.255.255.0
ip classless
no ip http server
Show VTP Counters shows this:
VTP pruning statistics:
Trunk Join Transmitted Join Received Summary advts received from
non-pruning-capable device
R-CORE-1#show vtp coun
VTP statistics:
Summary advertisements received : 0
Subset advertisements received : 0
Request advertisements received : 0
Summary advertisements transmitted : 0
Subset advertisements transmitted : 0
Request advertisements transmitted : 0
Number of config revision errors : 0
Number of config digest errors : 0
Number of V1 summary errors : 0
R-CORE-1#
What have I done wrong - I cant seem to use trunk commands on this but reading a cisco tech thing the above should work !?!?
I have added a switch to the integrated switch and these are communicating fine:
VTP statistics:
Summary advertisements received : 3
Subset advertisements received : 1
Summary advertisements transmitted : 3
Subset advertisements transmitted : 1
Request advertisements transmitted : 11
Gi1/0/2 0 0 0
Fa1/0/16 0 0 0
Thanks for any help
Ed
rolf.fischer_2
Level 5
Level 5
I do not know the C2812 but it's a router, right?
The purpose or VTP is distributing the VLAN.dat-File among switches which use to have a VLAN-configuration.
What you did with the router is configuring L3-subinterfaces which add a vlan-tag to the transmitted frames in order to communicate to a (switch-)trunkport.
The trunk should work fine but that has nothing to do with VTP.
A 'dir all-filesystems' on both devices should show that the switch has a file named vlan.dat but the router has not.
glen.grant
This is like a regular ios switch . You need to create the vlans. you do not use subinterfaces like on a normal router port. This is on the assumption this is like a 4 or 8 port switchcard . If this is just a router port , this does not apply .
router> vlan database
vlan 2
exit
conf t
vtp domain test
vtp mode transparent
exit
conf t
int vlan 1
ip address ip address 10.1.1.254 255.255.255.0
no shut
int vlan 2
no shut
int g1/0
switchport
switchport encapsulation dot1q
switchport mode trunk
switchport trunk allowed vlan 1,2
Both your answers make sense unfortauntly there seems to be some misrepresentation on this series of router.
It a integrated router 2821 and I tried using int vlan 1 and switchport command and it doesnt recongise them.
Everything works apart from the vlan vtp replication, it seems and there fore I cant assign ports further down the chain to a vlan......
Thanks for any pointer
Ed
Is it a problem with the fact that the vtp output shows no trunk ports ?? as the clients do ?
Ed
