VTP v3 primary ?
paolo bevilacqua
Can one set an IOS switch as VTP v3 primary database? Otherwise one can't configure VLANs in Server mode ?!?
2 Accepted Solutions
Hello Paolo,
VTPv3 is supported on 2960 switches starting with IOS version 12.2(52)SE. Version 3 has to be enabled explicitly on a switch using the vtp version 3 global configuration command - the version setting will not be inherited from other switches in the VTP domain automatically, contrary to VTPv1/VTPv2.
Setting a switch to be a VTP server (not a primary VTP server) is performed in global configuration mode using the vtp mode server command. This is a necessary prerequisite. Afterwards, if this switch should become a VTP primary server, the following command must be entered in the privileged EXEC mode (not in configuration mode):
vtp primary vlan
The vlan keyword can be omitted - it describes a so-called feature for which this switch is to become a primary VTP server (currently, two features are supported: VLAN and MST).
If this does not work please let us know, and also include the IOS version you are using. Optionally, the current VTP configuration and the transcript of the unsuccessful attempt to become the VTP primary server would also be helpful.
Best regards,
Peter
Paolo,
Thank you. You have probably misread my previous reply: the vtp primary command is not accessible via configuration mode (because it is a runtime state, not a configuration setting) but rather simply in the privileged EXEC mode itself, i.e.:
Switch# vtp primary vlan
Can you please try this out? Thanks!
Best regards,
Peter
13 Replies 13
Edison Ortiz
What platform are we talking about?
With the 6500, by default switches are configured as VTP v3 secondaries but this can be change with the CLI VTP Primary
More information can be found in the documentation:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/vtp.html#wp1051097
If the question is not related to the 6500 platform, then my apologies.
A  2960 switch. There is no "primary" option for VTP commands.
Hello Paolo,
vtp primary vlan
Best regards,
Peter
As mentioned above - there is no "vtp primary" option. Using latest IOS on  a WS-C2960-24PC-L.
BSL-SW-2(config)#vtp version 3
BSL-SW-2(config)#vtp mode server
Device mode already VTP Server for VLANS.
BSL-SW-2(config)#vtp ?
  domain     Set the name of the VTP administrative domain.
  file       Configure IFS filesystem file where VTP configuration is stored.
  interface  Configure interface as the preferred source for the VTP IP updater address.
  mode       Configure VTP device mode
  password   Set the password for the VTP administrative domain
  pruning    Set the administrative domain to permit pruning
  version    Set the administrative domain to VTP version
BSL-SW-2#
Paolo,
Best regards,
Peter
Works fine indeed... Thanks Peter!
Paolo,
I am glad it works. Thank you for the generous rating!
Best regards,
Peter
Thank you Peter, that solved my issue
Thanks Paolo,
all your information is very clear and valuable.
I'm glad when I found your replies.
A CCNP Student
Peter,
    Are there any caveats to performing the VTP Primary command while a 3850 stack live in production?
Leo Laohoo
It's not all the time to see Paolo get stumped at something!
hujatnoorie
thanks it solved my problem.
eAgencyInc
See the highlighted Device ID and Name of THIS device and it is stated that THIS device is Primary. However, when I try to edit the VLAN config, I get an error saying it is NOT the Primary. So which is it?
sw2hq#show vtp status
VTP Version capable : 1 to 3
VTP version running : 3
VTP Domain Name : eahq
VTP Pruning Mode : Enabled
VTP Traps Generation : Disabled
Device ID : 0017.596c.af00
Feature VLAN:
VTP Operating Mode : Server
Number of existing VLANs : 9
Number of existing extended VLANs : 0
Maximum VLANs supported locally : 255
Configuration Revision : 6
Primary ID : 0017.596c.af00
Primary Description : sw2hq
MD5 digest : 0x70 0x6F 0x8A 0xC3 0x7E 0xFA 0x05 0xC3
0x49 0x3C 0x8D 0xCF 0x96 0xF3 0x66 0xFD
Feature MST:
VTP Operating Mode : Transparent
Feature UNKNOWN:
Error when attempting to edit the VLAN config:
sw2hq(config)#vlan 7
VTP VLAN configuration not allowed when device is not the primary server for vlan database.
I was going to make it the Primary as you described but I'm shown that it already IS the Primary. Could it be not?
EDIT:
Apparently, it could. Even though it said it already was Primary and other switches confirmed it, I made it Primary again and that worked, just as you described and others confirmed.
