vtp with switch enterasys
jvcancelli1
Community Member
I need to install vtp in my network, all switches I am Cisco, but Core is enterays, Core goes to direct these packages vtp?
ycae
Level 3
Level 3
as far as you have .1q for the trunk i think that there should be no problem for vtp.
Yves
Friend,
Though enterasys supports VLAN propogation similar to VTP in Cisco, it does not understand cisco's implementation.
For this you will have to create a dot1q trunk between the switches and make sure all the vlans exiist in both the switches and are allowed over the trunk.
HTH, rate if it does
Narayan
