vWAAS network card
GaeMi
Level 4
Level 4
Hi.
I am trying to build vWAAS using KVM.
We will be installing KVM on a server that is not a UCS server.
There is one thing I want to ask before installing.
Should I use only CISCO network cards?
Can I deploy vWAAS with any network card?
Reza Sharifi
These are the supported platforms:
https://www.cisco.com/c/en/us/td/docs/app_ntwk_services/waas/vwaas/vwaas-623/vwaas-install-config/v-intro.html#43932
The following platforms are supported for Cisco vWAAS:
  • Cisco Unified Computing System (UCS)
  • Cisco UCS E-Series Servers
  • Cisco UCS E-Series Network Compute Engines (NCEs)
  • Cisco ISR-4000 Series
  • Microsoft Azure Cloud
Reza Sharifi
