Wan design
soumik1979
Dear all
We are going to connect a branch office with main office by 2mbps leased line and cisco 1841 router.
The main office LAN ip is 192.168.0.0/24 and branch office ip will be 192.168.3.0/24.Can any body give me the router configuration at both end with EIGRP routing protocol.We are having our domain controller at main office.I want that users at branch office will connect to this domain controller.Is it possible.If possibe then tell me how.Please discuss about the configurations...
ropethic
Level 4
Level 4
Attached is the EIGRP configuration guide. This is a fairly simple configuration for only two sites.
Please review
I shall use 192.168.254.0/30 on the serial interface.Then for main office the configuration will be
router eigrp 100
network 192.168.0.0
netwotk 192.168.254.0
no auto-summary
On branch
router eigrp 100
no auto-summary
network 192.168.254.0
network 192.168.3.0
The IP of the Ethernet interface of the router will the gateway at both ends computers so that the users at the remote office can access to the main office servers.
Is that ok????.What I have to do so that the users at the branch office can connect tha active directory at the main office....
Yes, the gateway for servers / users is the ethernet IP.
Users will be able to access the DC provided the route to the server network is int he routing table, which it will be.
You can use the 10 network for your WAN shown in previous answer.
Tshi M
Level 5
Level 5
Router_Main
int fa0/1
ip address 192.168.0.1 255.255.255.0
int s0/1
ip address 10.1.1.1 255.255.255.252
router eigrp 2
no auto-summary
network 192.168.0.0 0.0.0.255
network 10.1.1.0 0.0.0.3
Router_Branch
int fa0/1
ip address 192.168.3.1 255.255.255.0
int s0/1
ip address 10.1.1.2 255.255.255.252
router eigrp 2
no auto-summary
network 192.168.3.0 0.0.0.255
