Wan link etherchannel on switches
prashantrecon
Two sites withtwo  switches etherchannel concept for wan link
Does it work? Please suggest
On switch1--site 1
interface GigabitEthernet1/0/1--Wan link1
no switchport
no ip address
channel-protocol lacp
channel-group 1 mode active
interface GigabitEthernet1/0/2--wan link2
no switchport
no ip address
interface P01
no switchport
ip address 192.168.0.52 255.255.255.0
int valn 222
ip address 10.1.1.1 255.255.255.0
no shutdown
int vlan 333
ip address 172.18.1.1 255.255.255.0
no shutown
ip route 172.19.2.0 255.255.255.0 192.168.0.52
ip route 172.20.2.0 255.255.255.0 192.168.0.52
On switch2--site2
interface Po1
no switchport
ip address 192.168.0.51 255.255.255.0
interface GigabitEthernet0/1--wanlink1
no switchport
no ip address
interface GigabitEthernet0/2-wanlink2
no switchport
no ip address
int valn 21
ip address 172.19.2.1 255.255.255.0
no shutdown
int valn 45
ip add          172.20.2.1 255.255.255.0
no shut
ip route 172.18.2.0 255.255.255.0 192.168.0.52
ip route 10.1.1.0 255.255.255.0 192.168.0.52
7 Replies 7
smehrnia
Level 7
Level 7
yes it should work. but you need to change the Next Hop ip address on Site 1:
ip route 172.19.2.0 255.255.255.0 192.168.0.51
ip route 172.20.2.0 255.255.255.0 192.168.0.51
Hope it Helps,
Soroush.
Hope it Helps!
Soroush.
Ya typed it wrongly.
But today when i tried on My lan environement with same config from switch 1 when i traced it to
172.19.2.1  it was going to 192.1168.0.51 than to 192.168.0.52 and again to 192.168.0.51 looping taking place
Why this is happening ?
if you successfully setup the L3 etherchannel, and its up up. then the rest is a routing loop, could u post sh ip route sw1 and sw2? u might have typed something wrong in there
HTH,
Soroush.
Hope it Helps!
Soroush.
Hi please find the config done by me
mum#sh running-config
Building configuration...
Current configuration : 1778 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname mum
no aaa new-model
switch 1 provision ws-c3750g-24ts-1u
ip subnet-zero
ip routing
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface Port-channel1
no switchport
no switchport
no ip address
no switchport
no ip address
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
switchport access vlan 500
interface GigabitEthernet1/0/6
switchport access vlan 501
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface Vlan1
no ip address
interface Vlan500
ip address 172.18.2.1 255.255.255.0
interface Vlan501
ip address 172.20.2.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.0.51
ip http server
control-plane
line con 0
line vty 5 15
End
pun#sh running-config
Current configuration : 1841 bytes
! Last configuration change at 00:35:18 UTC Mon Mar 1 1993
version 15.0
no service pad
hostname pun
boot-start-marker
boot-end-marker
no aaa new-model
system mtu routing 1500
ip routing
no switchport
interface Port-channel5
no switchport
no ip address
no switchport
no ip address
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
switchport access vlan 666
interface GigabitEthernet0/6
switchport access vlan 665
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface Vlan1
no ip address
interface Vlan665
ip address 172.17.2.1 255.255.255.0
interface Vlan666
ip http server
ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.0.52
logging esm config
line con 0
line vty 5 15
end
PLease replu ASAP
Hi Prashant,
Try extended ping with Source IP of Vlan.
Smitesh
your config looks fine, with this configuration, are your ip addresses involved in the trace process, all within your local ranges already set on vlan interfaces? coz if not, a loop might occure.
try this, remove the default route and add below cmnds, see if its any success:
SW1
ip route 172.17.2.0 255.255.255.0 192.168.0.51
SW2
if it didnt work, send a show ip route and show etherchannel sum here.
HTH,
Soroush.
Hope it Helps!
Soroush.
Hi All
Another problem on eteherchannel
Etherchannel for gi1/32 and gi1/0/39 is working fine
But etherchannel for gi1/33 and gi1/0/40 is not up
On site1                      on site2
gi1/32(ISP 1)                     gi1/0/39(ISP 1)
gi1/33(ISP2)                        gi1/0/40(ISP2)
gi1/32 and gi1/0/39  on site1 and site2 bundled with etherchannel
gi1/33 and gi1/0/40 on site1 and site 2 are bundled withe etherchannel
Interface status
Gi1/0/39                     connected    routed     a-full  a-100 10/100/1000BaseTX
Gi1/0/40                     suspended    routed       full    100 10/100/1000BaseTX
Gi1/32       "tata point to poi connected    routed     a-full  a-100 10/100/1000BaseT
Gi1/33                          notconnect   routed     full    100 10/100/1000BaseT
Note -Duplex seetings on gi1/33  and gi1/0/40 are same
