WAN PORT PING ISSUE
wajid dabir
I have terminated my WAN link on cisco 1921 router,port is coming up but i am not able to ping the remote end ip address.i have change duplex ,speed and bandwidth also,but still not pinging.
for cross check i have directly connected WAN link to laptop ,now i can ping the remote end ip.
What can be issue,how do i solve this problem.
cadet alain
could you elaborate a little more please because it is very vague description.
did you verify you router end had an ip address ? did you verify arp was working correctly?
Alain
mfurnival
Level 4
Level 4
If you could post "show ip interface brief" and "show run" while plugged in to the WAN that would be helpful.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2013.06.18 14:42:55 =~=~=~=~=~=~=~=~=~=~=~=
CCCC
          THIS SYSTEM IS FOR THE USE OF AUTHORIZED USERS ONLY.
USERS HAVE NO EXPLICT OR IMPLICIT EXPECTATIONS OF PRIVACY.
ANY OR ALL USE OF THIS SYSTEM AND ALL FILES ON THIS SYSTEM
MAY BE INTERCEPTED,MONITORED, RECORDED, COPIED, AUDITED,
INSPECTED, AND DISCLOSED TO THE NECESSARY AUTHORITIES. BY
USING THIS SYSTEM, THE USER CONSENTS TO SUCH INTERCEPTION.
UNAUTHORIZED OR IMPROPER USE, OR ATTEMPTED USE, OF THIS
SYSTEM MAY RESULT IN ADMINISTRATIVE DISCIPLINARY ACTION AND
CIVIL AND CRIMINAL PENALTIES. BY CONTINUING TO USE THIS SYSTEM
YOU INDICATE YOUR AWARENESS OF, AND CONSENT TO THESE TERMS
AND CONDITIONS OF USE. LOG OFF IMMEDIATELY IF YOU DO NOT AGREE
TO THE CONDITIONS THAT ARE STATED IN THIS WARNING.
User Access Verification
Username: cisc             bharti
Password:
% Authentication failed
Username: cisco
Password:
IMCL-AMD01-RTR002#telnet 192.168.100.3
Trying 192.168.100.3 ... Open
Cisco Configuration Professional (Cisco CP) is installed on this device.
This feature requires the one-time use of the username "cisco" with the
password "cisco". These default credentials have a privilege level of 15.
YOU MUST USE CISCO CP or the CISCO IOS CLI TO CHANGE THESE  PUBLICLY-KNOWN
CREDENTIALS
Here are the Cisco IOS commands.
username   privilege 15 secret 0
no username cisco
Replace and with the username and password you want
to use.
IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL NOT BE ABLE
TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF.
For more information about Cisco CP please follow the instructions in the
QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp
Username: bha          cisco
Password:
% Login invalid
Username: bharti
Password:
% Password expiration warning.
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
Replace and with the username and password you want to
use.
IMCL-AMD02-RTR002#sh run
Building configuration...
Current configuration : 5378 bytes
! Last configuration change at 09:10:18 UTC Tue Jun 18 2013 by bharti
version 15.2
hostname IMCL-AMD02-RTR002
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
no ip icmp rate-limit unreachable
ip cef
--More--                           !
no ipv6 cef
crypto pki trustpoint TP-self-signed-2300688261
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2300688261
revocation-check none
rsakeypair TP-self-signed-2300688261
crypto pki certificate chain TP-self-signed-2300688261
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32333030 36383832 3631301E 170D3133 30333138 31313230
  34345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 33303036
--More--                             38383236 3130819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100E3EE 3FBEDA89 F2F14A97 4D53F1AB 86260E70 70CD1EAF E7D68633 39E4C90A
  0F520529 06C02735 2990A550 6C16EFC2 CA7E2EA5 AD193443 9E3066BB 43D86D22
  6824BCC2 B6BAAA9A 03311071 3609AB1C AB1FCBBA 627CFDD1 8D5592A1 D4740DBF
  2B0E6096 5883223F 434E63F6 F5CEC3EE B570BCBD F9DA8F63 649E4C4B D9E0B5F8
  F1350203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 142F4DE0 85958184 AD44AD32 08A999A6 EF6CA9CA 15301D06
  03551D0E 04160414 2F4DE085 958184AD 44AD3208 A999A6EF 6CA9CA15 300D0609
  2A864886 F70D0101 05050003 81810047 D8BEFDAC BBA65111 D28B61FD 6B7DB752
  B063099F 8D6EF476 C770D879 AF94587F 71CF526A 9669D3B7 DDE6FCF4 C924D884
  E9816526 7F72DDDE 75450F6C 2FDC0289 19B3A894 09C7C2D4 C5C54C04 83FA99C6
  37668C4B 135AE2AF 4FB34997 DA6C395A 119A235C 85920B2E 4FDF56F3 A69E3C8E
  74818062 E123F2FB B6CD55FB B84B87
      quit
license udi pid CISCO1921/K9 sn FGL171220L2
username bharti privilege 15 password 0 bharti
redundancy
--More--                           !
csdb tcp synwait-time 30
csdb tcp idle-time 3600
csdb tcp finwait-time 5
csdb tcp reassembly max-memory 1024
csdb tcp reassembly max-queue-length 16
csdb udp idle-time 30
csdb icmp idle-time 10
csdb session max-session 65535
interface Embedded-Service-Engine0/0
no ip address
shutdown
--More--                           interface GigabitEthernet0/0
description LAN-CONNECT
ip address 192.168.100.3 255.255.255.0
standby 1 ip 192.168.100.1
standby 1 preempt
duplex auto
speed auto
interface GigabitEthernet0/1
bandwidth 1024
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1/0
bandwidth 1024
ip address 10.227.35.38 255.255.255.252
duplex full
speed 100
interface FastEthernet0/1/1
no ip address
           shutdown
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1/0
ip route 10.227.35.64 255.255.255.252 10.227.35.37
control-plane
banner exec ^C
--More--
this session.
use.
^C
banner login ^C
--More--
CREDENTIALS
no username cisco
to use.
^C
line con 0
login local
line aux 0
           line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
IMCL-AMD02-RTR002#sh int fa
IMCL-AMD02-RTR002#sh int fastEthernet 0/1/0
FastEthernet0/1/0 is up, line protocol is up
  Hardware is FastEthernet, address is b0fa.eb3a.e908 (bia b0fa.eb3a.e908)
  Internet address is 10.227.35.38/30
  MTU 1500 bytes, BW 1024 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:05:41, output 00:00:02, output hang never
  Last clearing of "show interface" counters 02:02:25
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     22 packets input, 7772 bytes
     Received 22 broadcasts (0 IP multicasts)
     0 watchdog
      2431 packets output, 189416 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier
IMCL-AMD02-RTR002# exit
[Connection to 192.168.100.3 closed by foreign host]
IMCL-AMD01-RTR002#exit
first do this:
no ip route 0.0.0.0 0.0.0.0 FastEthernet0/1/0
ip route 0.0.0.0 0.0.0.0 x.x.x.x  where x.x.x.x is your next-hop IP
Then try to ping 8.8.8.8 and if it is successful but you can't ping the other end it is surely because they filter ICMP.
Alain
