05-10-2013 08:21 PM - edited 03-07-2019 01:18 PM
I have problem with my cisco switch 2970, please somebody advise me. Thanks
Initializing flashfs...
flashfs[1]: 5 files, 1 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15998976
flashfs[1]: Bytes used: 5935616
flashfs[1]: Bytes available: 10063360
flashfs[1]: flashfs fsck took 2 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC interface Loopback Tests : Begin
POST: CPU MIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
POST: PortASIC CAM Subsystem Tests : Begin
TCAM (asic:6) walking-one test failed
Write: 80_00000100_00000000-00_00000000_00000000
Read: 80_00000000_00000000-00_00000000_00000000
POST: POST Failed
POST: PortASIC CAM Subsystem Tests : End, Status Failed
POST: CAM test failed
POST Failed: disabling stack links and shutting down SDP
driver class subsystem initialization failed
A summary of U.S. laws governing Cisco cryptographic products may be found at:
cisco WS-C2970G-24TS-E (PowerPC405) processor (revision L0) with 122880K/8184K bytes of memory.
Processor board ID CAT0939N5LW
Last reset from power-on
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:15:C6:8E:15:00
Motherboard assembly number : 73-9095-07
Power supply part number : 341-0045-01
Motherboard serial number : CAT094019XU
Power supply serial number : LIT0910053F
Model revision number : L0
Motherboard revision number : A0
Model number : WS-C2970G-24TS-E
System serial number : CAT0939N5LW
Top Assembly Part Number : 800-24261-05
Top Assembly Revision Number : B0
Hardware Board Revision Number : 0x02
!!! WARNING: The switch is not usable !!!
Unable to create l2trace server process, socket_open() failed
Press RETURN to get started!
00:00:46: hl2mcm_core_process: hl2mcm_install_hl2mcm_ctrl_entries() failed.
00:00:46: %SYS-3-HARIKARI: Process HL2MCM top-level routine exited
00:00:47: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlanCannot Get the number of ports in MAC notification
00:00:47: %SW_VLAN-4-IFS_FAILURE: VLAN manager encountered file operation error: call = ifs_read_until (header) / file = / code = 21 (Is a directory) / bytes transfered = -1
-Traceback= 15CAB8 158B78 C41890 C38E7C
00:00:48: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C2970 Software (C2970-LANBASEK9-M), Version 12.2(35)SE, RELEASE SOFTWARE (fc2)
05-10-2013 10:18 PM
Hi Aji,
This message typically means a hardware failure.
POST: POST Failed
If this switch is under contract, it should be RMA'd. No further troubleshooting to be done. ( you may see tht some suggest to reload and format the flash and upload the new ios, but ths will not resolve most of the time. Hence avoid the delay and order the new switch by creating the RMA.)
Inayath
*Plz rate all usefull posts.
05-10-2013 11:03 PM
Hope you have a valid Service Contract because the switch is dead.
