way to get SPF part numbers
dallen00111111
I'm wondering if there is an easy way to get the part numbers for SFP modules that are plugged into our current 2960 and 3560 series switches without powering the switches down and pulling the modules out of the switches?  The switches are running IOS 12.2 if that makes a difference.
Thanks, in advance, for any assistance.
Douglas Allen
Brown County Community Unit School District
Mt. Sterling, IL
Can you please provide the complete IOS version?
When i log into one of the switches with the modules installed and in use, sh inventory  gives me the name of the interface, a description, a blank where PID should be, a blank where VID should be, and a serial number.
Hmmmm ... That'll be dependent on the IOS (maybe a bug) or the make/model of the SFP in particular.
Can you post the complete output to the command "sh idprom interface <SFP port>"?
5 Replies 5
Leo Laohoo
Command:  sh inventory
Leo,
When i log into one of the switches with the modules installed and in use, sh inventory  gives me the name of the interface, a description, a blank where PID should be, a blank where VID should be, and a serial number.  Is the description the part number?  I thought it would be the PID.
Douglas Allen
Leo,
Here is the output from the command, as requested:
General SFP Information
Identifier : 0x03
Connector : 0x07
Transceiver : 0x00 0x00 0x00 0x02 0x00 0x00 0x00 0x00
Encoding : 0x01
BR_Nominal : 0x0D
Vendor Name : CISCO-FINISAR
Vendor Part Number : FTLF1318P2BCL-CS
Vendor Revision : 0x30 0x30 0x30 0x30
Vendor Serial Number : FNS1111187H
Other Information
Port asic num : 04
Port asic port num : 03
SFP presence index : 00
SFP iter cnt : 288031342
SFP failed oper flag : 0x00000000
IIC error cnt : 0
IIC error dsb cnt : 0
IIC max sts cnt : 35
Chk for link status : 01
Link status : 01
Autoneg enable : 01
Flow control Pause : 00
Flow control asymPause: 00
Duplex mode : 01
PcsInfo : 0x032E10F0
MacInfo : 0x032E10E0 0x032E10D8
AutoNeg : 0x032E10D8 0x032E10E0
Sfp selection asic reg map
stbi : 0x02
sfpControl : 0x48
Regs Loc : 0xF0000000
SFF-8472 MSA EEPROM Data
000 : 03 04 07 00 00 00 02 00 00 00
010 : 00 01 0D 00 0A 64 37 37 00 00
020 : 43 49 53 43 4F 2D 46 49 4E 49
030 : 53 41 52 20 20 20 00 00 90 65
040 : 46 54 4C 46 31 33 31 38 50 32
050 : 42 43 4C 2D 43 53 30 30 30 30
060 : 05 1E 00 EB 00 12 00 00 46 4E
070 : 53 31 31 31 31 31 38 37 48 20
080 : 20 20 20 20 30 37 30 33 31 37
090 : 20 20 08 00 00 BF 00 00 02 65
100 : 82 C4 78 FE C2 A3 58 BF 65 67
110 : BF 1E 4E 2C 08 00 00 00 00 00
120 : 00 00 00 00 5E 4F 28 60
YETI INTERNAL REGS
Location=0xD8000500 : Value=0x00
Location=0xD8000501 : Value=0x00
Location=0xD8000502 : Value=0x00
Location=0xD8000503 : Value=0x00
Location=0xD8000504 : Value=0x00
Location=0xD8000505 : Value=0x00
Location=0xD8000506 : Value=0x00
Location=0xD8000507 : Value=0x02
Location=0xD8000508 : Value=0x00
Location=0xD8000509 : Value=0x40
Location=0xD800050A : Value=0x00
Location=0xD800050B : Value=0x00
Location=0xD800050C : Value=0x05
Location=0xD800050D : Value=0x00
Location=0xD800050E : Value=0x01
Location=0xD800050F : Value=0x00
Location=0xD8000510 : Value=0x0F
yetiIICinited : Value=0x00000001
yetiIICLockPassCnt : Value=0
yetiIICLockFailCnt : Value=0
yetiIICLockApp : Value=11
The IOS version appears to be (C3560-IPSERVICESK9-M) version 12.2(37) SE Release.
From this, it looks like the part number is FTLF1318P2BCL-CS.
Doug
I also forgot to say that I think this answers my question, at least for the information that I asked about in the original question.  Again thank you for your time and assistance.
Douglas Allen
