Wccp redirection 2811
avionics
are there any features like wccp for 2811 series or what is the best redirection method for traffic?
andrew.burns
Level 11
Level 11
WCCP is available on all versions of 2800 software and is commonly used as a transparent redirection method. The other transparent method is to use a L4 switch (Cisco CSS or something like that).
Alternatively, you can do non-transparent redirection (otherwise known as direct proxy routing) - but which method works for you depends on your infrastructure.
HTH - please rate useful posts (not just mine!)
Andrew.
