Hi Everyone,
Need to know on 3750 switch how can I verify if wccp redirection is configured?
Also how can I know which type of redirect is like GRE tunnel or layer 2?
Mahesh
Hi Mahesh,
Check with the below command Show ip wccp web-cache , It will display global information about the wccp in switch.
I believe GRE is not supported with 3750 wccp switch configuration.
Check out the below link on detailed configuration wccp in 3750 switches for more information.
http://www.cisco.com/c/en/us/support/docs/security/web-security-appliance/118006-configure-wccp-00.html
Hope it Helps..
-GI
Rate if it Helps..
