WCCP
visitor68
Level 5
Level 5
What is the benefit of doing proxy redirects through WCCP over PBR or just defaulting to the proxy server?
I'm not saying PBR is not an option and i don't want to put you off that solution if it is easier to implement.
You may not face any issues implementing PBR so don't let what i said stop you doing it, it was really i just wanted to make you aware of potential issues you may face.
In terms of setting the proxy setting in the browser we would never have done that if -
1) we could not have done it by group policy because there were so many users it would have been totally impractical if we couldn't have automated it
2) we could lock the desktop down so the user could not just change it
so there are considerations for that as well.
It really does depend on what is available/possible within the network already.
Jon
10 Replies 10
Jon Marshall
It depends on the setup really.
Assumng http/https for example WCCP has the flexibility to define clusters of content engines (using multicast) and direct certain traffic to certain clusters etc. Because of this the switch can effectively load balance client traffic between a set of content engines based on information learnt when the switch and the content engines first learn of each other. They also support MD5 authentication between the switch and content engines.
PBR on the other hand has none of this ability. It is a simpler way of doing it and although you can verify the next hop you are still only able to use unicast although that unicast address could in theory be a group of proxies.
Generally speaking PBR is a generic tool that can be used for proxy redirection (among many other things) but is does not have any of the additional features that may be useful for http/https etc redirection.
Both can be useful in an environment where you have no control over the end user devices and you do not want traffic allowed to the internet without going via a proxy.
That said in my last place we -
1) set the proxy in the web broswer. The desktop was locked down with group policies so it could not be changed.
2) because we used a proxy in the web browser we did not need a default route in the routing tables for internet traffic so even if a user connected their own laptop to the network they still could not get to the internet
3) we also only allowed the proxy to make http/https requests through the corporate firewalls so again without that proxy setting no access to the internet was available.
So it really comes down to your environment and your specific requirements.
Jon
Thanks, Jon....great stuff
I am pretty light when it comes to Internet access schemes, especially as they relate to security, in enterprise environments. In the environment in which I worked the longest. we defaulted to a firewall and that was that, nothing fancy. No WCCP, no proxy engines, period.
You described one way to do it, can you delineate a few other ways it can be done, taking into consideration browser configurations? Need to discuss with a client and dont want to look like a moron. :-)
If you don't set the proxy in the browser then there is no browser configuration to be done because you are then relying on the network configuration to redirect the traffic. Bear in mind if you have a centralised site where the proxy is then you don't necessarily need to configure WCCP/PBR in all the other sites, you can just configure it where the traffic comes into the main site and send it to the proxy. If you do this though you do need a default route in your routing tables on the other sites pointing back to the main site.
For larger enviornments using a proxy makes sense because -
1) it is a central point of control for internet access
2) it is more efficient use of your internet bandwidth because of caching
3) you can tie the proxy into other services such as virus checking, web sites allowed and not allowed etc.
4) you can lock down your outbound firewall access to only the proxy IP rather than have an open outbound policy for all clients
5) updates to web site lists etc. can be done centrally
obviously that is not to say  that you should not run a virus checker on the clients anyway, you should but it is an additional layer of protection.
If you set the proxy explicitly in the browser you can also use exception lists for internal web servers and if i remember correctly this can be done on domain name rather than IP (although i could be misremembering - sorry).
With WCCP/PBR you use either redirect lists or PBR acls and you would need to use IPs as far as i am aware for the exceptions. Worth mentioning as well with WCCP some switches do not support redirect lists which are used like acls to define which traffic to send to the proxy. What this means in practice is if you applied WCCP to an interface and it did not support redirect lists it basically means all http/https etc. traffic arriving on that interface is sent to the proxy which may or may not be what you want.
It really does depend on the company setup and their specific requirements.
Finally one thing none of them really fully protect against is a user or group getting their own internet line and using that. Using group policy as we did meant they couldn't use company devices but they could still connect their own devices and point them to their own line.
Using WCCP/PBR doesn't help either because if it is their own device they can simply point the default gateway to be the device connecting to their internet connection.
So neither is foolproof and you need additional security measures such as port security, authenticating to the network etc. to protect against that and they are not trivial to implement.
But it depends on what the company wants a proxy for.
And all of the above should be backed up by a written security policy that everyone is -
a) aware of
and
b) has signed up to
although i freely admit this can be one of the hardest things of all to achieve.
Hope some of that helped, please come back if you have further queries.
Jon
Jon, thanks. Good stuff to think about.
As for this client, he already uses a proxy, Bluecoat ProxySG. He uses WCCP to redirect to a pair of SGs in an HA cluster. He doesnt leverage multicast addressing - he just points to a unicast VIP. He also doesn't use the browser to redirect. The question posed to me is how I would work around not having WCCP. I'm using Dell Force10 switches.
Given his pretty simple setup and the fact that he doesn;t seem to be using much of WCCP's functionality (I saw the config - nothing to it, really), I think I can get away with PBR. I'll create a policy to block Bogons (RFC 1918 addresses) and forward the rest based on ports 80/443/23. I think that'll do it.
I checked out Juniper's redirect solution, and it uses PBR as I described.
Thoughts?
I think PBR could be used in this setup and it would work fine.
You are still just redirecting specific traffic to another IP address ie. the proxy VIP and you aren't actually modifying any of the IP addressing with PBR.
Just remember that if there are any internal websites that are not meant to be accessed via the proxy then you need to make sure they are not policy routed although that may not be an issue in your case.
The only other thing i would say is that i'm not familiar with the switches you mention and so the following may not apply but with some Cisco switches using certain things such as deny lines in your PBR acl is not recommended as they can have an adverse effect on the CPU of the switch.
Just something to be aware of.
Jon
Jon, you raise a good issue that I thought of before. Still trying to find the answer...
Is PBR in Cisco switches performed in hardware or software? or is it a combination of both. You mention ACLs causing the CPU to spike, but I thought ACL processing is done in TCAM (hardware).
PBR is done in hardware on Cisco switches but depending on the switch there are -
a) certain commands that are not supported
b) certain configurations that can cause packets to be sent to the main CPU ie. software switched.
When you define your acls for PBR using a deny line (which can be quite useful) causes the packets matched by that line to be software switched, or at least they did when i last checked.
So you need to be careful when you use PBR and you need to keep an eye on the CPU usage.
There are a number of threads on this site about PBR and, for example, the 3750 switch and CPU spikes and it is to do with the actual PBR confiiguration normally.
So firstly it's important to look at the configuration guides for your switch together with the IOS version. In the IP routing chapter PBR will be covered and there will guidelines/restrictions as to what is and isn't supported and what you should and shouldn't use in your PBR configuration.
Jon
Interesting. Perhaps it may be a better approach to simply leverage a proxy setting in the browser and depend on normal IP routing to reach the proxy engine. What do you think of that over PBR?
Jon
mhnedirli
WCCP is designed for proxy redirect but with pbr you are changing next hop of the packets and sometimes you can trouble with pbr. i have configured pbr for proxy but users trouble with some secure sites such as online trading etc. i think wccp is the best.
