WCCPv2 and IronPort S160 issues
Group IT
Hi all,
I have an IronPort S160 which has been working fine as an explicit proxy for a while, but I want to start using WCCPv2 instead (via a Cisco 1801 router).
I have followed so many guides and manuals but I jus can't get it to work. When all is activated, my clients just time-out when they attempt to access the internet.
I would be very grateful if anyone could lend some assistance.
On the IronPort I have:
  • Enabled WCCPv2 under 'Network'...'Transparent Redirection'.
  • Created a 'Service Profile Name' labelled 'web_cache' and configured it as 'Standard Service ID: web-cache (destination port 80)'.
  • Assigned router addresses of 10.11.1.254, 10.11.22.254, 10.11.23.254.
| IRONPORT |
  | | +-M1: 10.11.23.240------+     +----------+
  | +---P1: 10.11.1.250-------------|   CORE   |
  |                           +-----| SWITCHES |               +--------+
  +-----P2: 10.11.2.249-------+     |          |--10.11.2.250--| WWW GW |
   +-------------[vlan1]10.11.1.254---+ | | |
| 1801 ROUTER |--[vlan2]10.11.2.254-----+ | |
|     +---------[vlan23]10.11.23.254-----+ |
+---------------[vlan22]10.11.22.254-------+
My Cisco 1801 router config is as follows:
Building configuration...
Current configuration : 3862 bytes
version 12.4
service password-encryption
hostname rtr-hq1-2
boot-start-marker
boot-end-marker
logging buffered 51200 debugging
enable secret 5 $1$jDxW$9C6g05.A8TT2xhmyFmVzX/
aaa new-model
aaa authentication login default local
aaa authentication enable default enable
aaa authorization exec default local
aaa session-id common
resource policy
ip wccp web-cache
ip cef
crypto pki trustpoint TP-self-signed-1093762028
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1093762028
revocation-check none
rsakeypair TP-self-signed-1093762028
crypto pki certificate chain TP-self-signed-1093762028
certificate self-signed 01
  3082023F 308201A8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31303933 37363230 3238301E 170D3131 30363230 31303531
  30335A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 30393337
  36323032 3830819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100CCB9 C9A85C7B AA02244C 6EFE8B7E A76382C9 E830F40D 49903E07 B087E432
  04658712 417FBA35 36063274 780AACB7 6FF535A6 A699D012 7690F484 0E71E471
  E74F318F AC96A75A 39916AB3 31972A6F E4475252 E030BFD0 E0172937 9E7C8D03
  CC498443 E937615A 9DCE36FB 45E8B17B F01B3E0A AFC7091C 779B9A73 B3D16957
  43A30203 010001A3 67306530 0F060355 1D130101 FF040530 030101FF 30120603
  551D1104 0B300982 07687132 2D727472 301F0603 551D2304 18301680 1420B0B5
  EB9D1E93 F93C9DAA 78E22A47 A093A06E 8F301D06 03551D0E 04160414 20B0B5EB
  9D1E93F9 3C9DAA78 E22A47A0 93A06E8F 300D0609 2A864886 F70D0101 04050003
  818100AD 0B3D4707 0856AC6D C0F51A1B A780CCDF F71C1573 03C988FD 6A20AF2B
  17C1B427 77227F7C 568B7AB5 5B88D39F AA33835F FC6457F4 284AA738 20C14A1A
  5520C943 17937BDD DA1B6E3F CAF812F9 26FE66EF 4D62BE34 817E6C4C BAE1E19E
  AC875506 BDF2A5EA A4CB7D8C 97351B08 2134C732 ED21E8CD 57EEB153 BE23DB0E 3B25DE
  quit
username ejohnson privilege 15 secret 5 $1$oUkZ$6uPrTcKxfAninwA32Q5Rx.
username sas-admin privilege 15 secret 5 $1$y8xH$BqdEH.vNU0XpEvwtTBI2m1
interface FastEthernet0
description $ETH-LAN$
ip address 10.11.200.100 255.255.255.0
shutdown
speed auto
half-duplex
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn point-to-point-setup
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
switchport access vlan 2
interface FastEthernet6
switchport access vlan 22
interface FastEthernet7
switchport access vlan 23
interface FastEthernet8
shutdown
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface Vlan1
ip address 10.11.1.254 255.255.255.0
ip helper-address 10.11.254.1
ip wccp web-cache redirect in
interface Vlan2
ip address 10.11.2.254 255.255.255.0
ip wccp web-cache redirect out
interface Vlan22
ip address 10.11.22.254 255.255.255.0
interface Vlan23
ip address 10.11.23.254 255.255.255.0
ip route 0.0.0.0 0.0.0.0 10.11.2.250 permanent
ip route 10.11.0.0 255.255.0.0 10.11.1.249 permanent
no ip http server
ip http secure-server
access-list 10 permit 10.11.1.250
access-list 121 permit tcp 10.11.0.0 0.0.255.255 any eq www
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipx permit
control-plane
line con 0
privilege level 15
line aux 0
line vty 0 4
webvpn context Default_context
ssl authenticate verify all
no inservice
end
Thanks in advance.
Best Regards,
Elliot
Richard Burts
Elliot
I think that on the Iron Port that you only need to specify one address for the router. But I do not know that having multiple addresses for the same router would cause problems.
Your drawing show the router and core switches but does not tell us much about their relationship. Are the core switches just layer 2 or are they layer2/layer 3? And in particular - is all inter vlan routing done on the router or is it possible that some routing is done on the core switches?
What output do you get for show ip wccp on the router?
Rick
Rick
Hi Rick,
Thank you very much for your reply.
I will try to answer your questions as best I can.
1) The switches are just layer 2, as far as I am aware.
2) Inter vlan routing is only done on the router.
I have since changed the interface facing the internet from a vlan (vlan2) to a layer 3 port (fe0), just incase WCCP had some inssue with operating on a vlan port.
My new config looks as follows:
| IRONPORT |
  | | +-M1: 10.11.23.250------+     +----------+
   +-------------[fe0]10.11.1.254-----+ | | |
When WCCPv2 is acivated on the IronPort and router, I see the following results on the router:
rtr-hq1-2#show ip wccp
Global WCCP information:
   Router information:
       Router Identifier:                   10.11.23.254
       Protocol Version:                   2.0
   Service Identifier: web-cache
       Number of Service Group Clients:     1
       Number of Service Group Routers:     1
       Total Packets s/w Redirected:       2221
         Process:                           127
         Fast:                             0
         CEF:                               2094
       Redirect access-list:               -none-
       Total Packets Denied Redirect:       0
       Total Packets Unassigned:           34
       Group access-list:                   -none-
       Total Messages Denied to Group:     0
       Total Authentication failures:       0
       Total Bypassed Packets Received:     0
rtr-hq1-2#show ip wccp web-cache detail
WCCP Client information:
        WCCP Client ID:          10.11.1.250
        State:                   Usable
        Initial Hash Info:       00000000000000000000000000000000
        Assigned Hash Info:      FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
        Hash Allotment:          256 (100.00%)
        Packets s/w Redirected:  705
        Connect Time:            00:01:53
        Bypassed Packets
          Process:               0
          Fast:                  0
          CEF:                   0
The "Total Packets s/w Redirected" seem to increase quite quickly, which I would guess suggests that the router is forwarding the requests out, but it's as though they're not reaching the IronPort.
Any further assistance is extremely well received.
Best Regards,
Here is a slightly more detailed breakdown of the immediate network revolving around the IronPort and router:
Thanks.
