WDS/RIS and Cisco DHCP options
durgeshk
I have configured DHCP service on cisco 3560 switch and I want to deploy WDS/RIS in my network. Now I have to configure our Cisco DHCP Server so that I can use PXE to install and capture Windows OS Images but I have to configure option 60 for that. This is easy in Microsoft DHCP server. Please help me to resolve this in switch level configuration.
iyde
Level 4
Level 4
Hi.
Do you mean that you have a DHCP server on the Cat3560 switch and want option 60 to be configured on that one?
Have you tried to configure "option 60 " in dhcp server configuration submode, i.e.:
conf t
ip dhcp pool
option 60
Or is it something completely different you are asking for?
HTH, Ingolf
tdavis85
I had this same issue and tried the options, but what fixed it for me was adding the next-server command on the DHCP pool instead of using the ip helper on the SVI.  Everything I've always read said to use the ip helper but how I was able to get it to work is to set the
next-server (PXE server address and DP address)
option 60 ascii "PXEClient"
Adding those two commands to the DHCP scope fixed it for me.  I know this is an old thread but hopefully it helps others in the future.
