Weird disconnection problem frequently between 3 cisco switch 2960 and two 3560
ahmet.ozkan
I have a communication problem between 3 switches and I have really need advise to solve the problem
The communication disconnect frequently (every 2-3 min for 10-15 sec)
I think the problem originate from main 3560 switch  because the communication interrupt both other two switches that come from main switch
The problem is weird because I can solve the problem temporary by use simple 4 port switch between two Cisco switch and communication established without interrupt
Topology very simple like below
3 rd 2960 switch --------------Main 3560 switch-------------------- 2nd 3560 switch
Temporary solution without vlans
3 rd 2960 switch ---------simple hub (4 port)-----------Main 3560 switch----------simple hub (4 port)---------- 2nd 3560 switch
Main Switch and 3 rd 3560 switch  Trunk config example
interface GigabitEthernet0/20
switchport trunk native vlan 10
switchport mode trunk
switchport nonegotiate
2960 switch example
interface GigabitEthernet1/0/48
Trunk port interface
MainSwitch#sh int gi0/20
GigabitEthernet0/20 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is b0fa.eb7e.1c14 (bia b0fa.eb7e.1c14)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:54, output 00:00:04, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute output rate 2000 bits/sec, 3 packets/sec
703255 packets input, 104881192 bytes, 0 no buffer
Received 608879 broadcasts (581903 multicasts)
0 watchdog, 581903 multicast, 0 pause input
2843929 packets output, 288502274 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
231 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
What I tried to determine the problem;
  • There is no physical redundant connection  even so first I made main switch spanning-tree vlan 1-4094 priority 24576 and other spanning-tree vlan 1-4094 priority 28672 and spanning-tree vlan 1-4094 priority 32768 on top of that I use the command no spanning-tree vlan 1-4094 for 3 switches so that the be unaffected spanning-tree  issue
  • I used simple 4 port switch (like hub) between 2 cisco switch by change trunk port to access port.  Yes communication was established without interrupt but I can only used one vlan. And No one wants to use simple switch between two Cisco switch
  • I tried 3 different cat 6 cable to determine physical connection problem but result was same Actually I have already two connection problem come from main switch to other two and sh interface command reliability is 255/255 there is no bad physical connection certainly
  •  I change vtp mode off for 3 switch
  • I change trunk port to access port switches connection for 1 vlan connection but result was same, disconnect issue went on frequently
  • I closed all port of the 2960 switch except trunk port to be unaffected end devices and I tried to pint vlan ip and disconnect issue went on frequently
  • I check cpu usage but there is no meaningful a peak
  • I removed the command  below trunk ports        storm-control broadcast level 3.00
    storm-control multicast level 3.00
    storm-control action shutdown
    storm-control action trap
  • I have also tried to change speed trunk port gigabit to 100 mb/s
Leo Laohoo
I don't see any line errors from the output above.  What about the output from the 2960?
"unknown protocol drops" is always present when the interface is in a Trunk.
I forgot to put 2960 output
You can see below
2960Switch#sh int gi1/0/48
GigabitEthernet1/0/48 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 84b5.1731.5ab0 (bia 84b5.1731.5ab0)
Last input 00:00:18, output 00:00:00, output hang never
5 minute input rate 5000 bits/sec, 5 packets/sec
5 minute output rate 3000 bits/sec, 4 packets/sec
133636 packets input, 15697242 bytes, 0 no buffer
Received 126536 broadcasts (31637 multicasts)
0 watchdog, 31637 multicast, 0 pause input
21689 packets output, 6545996 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
I don't see anything wrong.
