Weird Routing problem
dan_track
I can't get my head round this problem.
I have an office (Site 2) connected via WAN conneciton from a switch in site 1. Both sites are running eigrp.
In site 2 when I do a sh ip ro 10.45.61.0 I get route not found. However if I do the same in site 1 on the switch I get:
sh ip ro 10.45.61.0
Routing entry for 10.45.61.0/24
Known via "static", distance 1, metric 0
Routing Descriptor Blocks:
* 10.44.99.254
Route metric is 0, traffic share count is 1
My eigrp config on both sites looks like this:
Site1:
router eigrp 100
passive-interface default
no passive-interface Vlan756
no passive-interface Vlan776
no passive-interface Vlan999
network 10.10.51.92 0.0.0.3
network 10.10.51.100 0.0.0.3
Site2:
router eigrp 100
no passive-interface Vlan2
no passive-interface Vlan2080
no passive-interface Vlan2083
network 10.10.51.88 0.0.0.3
network 10.10.51.96 0.0.0.3
network 10.66.1.0 0.0.0.255
network 10.66.2.0 0.0.0.255
network 10.66.50.0 0.0.0.255
distribute-list bcn-eigrp-out out Vlan776
distribute-list bcn-eigrp-out out Vlan2080
distribute-list bcn-eigrp-out out Vlan2083
distribute-list bcn-eigrp-out out GigabitEthernet1/0/48
auto-summary
Any thoughts on why it's not propgating?
Dan
andrewswanson
Level 7
Level 7
you should add command "redistribute static" under router eigrp 100 at site 1 (or use a network statement). see:
http://supportwiki.cisco.com/ViewWiki/index.php/How_does_EIGRP_redistribute_a_static_route_to_an_interface%3F
hth
9 Replies 9
andrewswanson
Level 7
Level 7
hth
Many thanks for that.
Following on from this when I run the following:
sh ip eigrp topology | i 10.45.61
P 10.45.61.0/24, 0 successors, FD is Inaccessible
I can't see why the route is inaccessible? Would anyone have an idea why that might be?
Dan
To add to the above can you please explain why the route isn't being propgated by eigrp. If the static route isn't being propagated why can't the eigrp route be propagated?
Dan
hi
are you running another routing protocol other than eigrp at site 2?
also, do you have a metric setup on site 1 for the redistributed routes? see:
http://supportwiki.cisco.com/ViewWiki/index.php/Routes_are_not_redistributed_into_EIGRP
hth
andy
Thanks for the reply. No no other routing protocols at site2. To be honest site2 is relatively simple as it's just a small office. I've included the eigrp config in my first post.
Site 1 has a few static routes. Any thoughts?
Dan
Hi Dan
did you add the "redistribute static" command under the eigrp process on site 1 - if so, did you specify the metric?
cheers
andy
Sorry, I may have confused people. I understand that I need to add that redestribute command in.
I've been reading in the last hour on the questions I have posed and have found the following:
"when the FD is inaccessible in the EIGRP topology table, the router is not using that EIGRP route in its routing table. Usually, the route is overridden by another routing protocol that has lower administrative distance."
This explains the FD question I had. My static route is being placed in the routing table of the switch instead of the eigrp route and so eigrp topology is showing my route as inaccessible.
My guess is if I remove the static route in the switch on site 1 the route will then propagated to site 2.
I'm going to do that in the next 10 minutes and I'll report back on what I find.
Thanks for your help.
Dan
Great,
That worked, eigrp is now propagating the route.
Thanks everyone.
