Well known, registered and Ephemeral ports
Lewis Quin
Hi all,
I understand that well known ports (0 - 1023) are reserved for well known or common services (such as http, smtp, etc) and I also understand that Ephemeral ports are short lived dynamic assignements typically used for specifying a source port but I want to make sure I understand what a registered port is.
My understanding a registered port is a port that falls outside of the other two ranges (well known and Ephemeral) and is typically used in-house if you were creating custom applications?  if this is correct I dont understand why these numbers would need to be registered with IANA (as it says companies should).
Thanks in advance!
acampbell
Hi Lewis,
Have a look t this link
https://en.wikipedia.org/wiki/Registered_port
Alex
Regards, Alex. Please rate useful posts.
