IP device tracking on 3850 Switches (Reposting - Need help)
Jason Flory
Hello Everyone
I am reposting this question because it seems like the posts are generating more questions then answers and really need to get some expert guidance around this issue.
We have 2 3850 stacks in our corporate office.  One stack is for users and the other is for severs.  We have been having alot of false positive duplicate IPs errors on our servers and have been finding many others out there having issues with IPDT on 3850s.  The recommendation is to disable.  I want first fully understand this and second make sure I am not creating other issues down the line.
In our environment the server stack is the one that has the SVIs and does all layer 3.  We also have several other stand alone switches that connect our blade servers to the server stack.
As an update I have change tracking delay to 10 and added command ip device tracking probe delay use-svi
First question:
In a multi switch environment which switch manages IP Device Tracking?  When I do show IP device tracking all on each switch it seems that a lot of the IPs being tracked are not directly connected nor are they only on the layer 3 switch.  Is there a way to control which switch does the tracking?
Second question:
If we turn this off using nmsp attach suppress on each interface what are the implications?
Hello
Can you post the config 3850 stacks?
res
Paul
Kind Regards
Paul
Here is summarized config for server stack.  This is our core for this site and handles all routing.  This switch has all the SVIs for the user stack.   Stacks are trunked together via 10 GB link.
The second config is the user stack which does not have any SVIs and only does layer 2.
Server stack:
version 15.0
no service pad
service timestamps debug datetime localtime show-timezone year
service timestamps log datetime localtime show-timezone year
service password-encryption
service compress-config
hostname sfn-sw1
boot-start-marker
boot-end-marker
vrf definition Mgmt-vrf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
aaa session-id common
clock timezone PST -8 0
clock summer-time PDT recurring
switch 1 provision ws-c3850-48t
switch 2 provision ws-c3850-48t
switch 3 provision ws-c3850-48t
flow record NETFLOW-RECORD-IN
 match ipv4 tos
 match ipv4 protocol
 match ipv4 source address
 match ipv4 destination address
 match transport source-port
 match transport destination-port
 match interface input
 collect transport tcp flags
 collect interface output
 collect counter bytes long
 collect counter packets long
 collect timestamp absolute first
 collect timestamp absolute last
 collect counter bytes layer2 long
flow record NETFLOW-RECORD-OUT
 match ipv4 tos
 match ipv4 protocol
 match interface output
 collect interface input
flow exporter NTAexport
 destination x.x.x.x
 source Vlan2
 transport udp 2055
 template data timeout 60
flow monitor NETFLOW-MON-IN
 exporter NTAexport
 cache timeout active 60
flow monitor NETFLOW-MON-OUT
 exporter NTAexport
ip routing
ip multicast-routing
ip domain-name ia-global.com
ip name-server x.x.x.x
ip device tracking probe use-svi
ip device tracking probe delay 10
ip device tracking
qos wireless-default-untrust
crypto pki trustpoint TP-self-signed-0
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-0
 revocation-check none
 rsakeypair TP-self-signed-0
spanning-tree mode rapid-pvst
spanning-tree vlan 1-4094 priority 8192
redundancy
 mode sso
class-map match-any non-client-nrt-class
  match non-client-nrt
policy-map port_child_policy
 class non-client-nrt-class
    bandwidth remaining ratio 10
interface Loopback0
 ip address 10.2.255.5 255.255.255.0
 ip mtu 1500
interface Port-channel18
 description SFS-CITRIX-XS3 Team
 switchport mode trunk
interface Port-channel19
 description sfn-ucs-a
interface Port-channel20
 description sfn-ucs-b
interface Port-channel21
 description SFS-CITRIX-XS10 Team
interface GigabitEthernet1/0/1
 description Masergy MPLS
 switchport mode access
 ip flow monitor NETFLOW-MON-IN input
 ip flow monitor NETFLOW-MON-OUT output
 speed 100
 duplex full
interface GigabitEthernet1/0/2
 description ASA Lan
 switchport access vlan 254
 duplex full
interface GigabitEthernet1/0/3
 description TMG
interface TenGigabitEthernet3/1/1
 channel-group 19 mode active
interface TenGigabitEthernet3/1/2
interface Vlan1
 ip address x.x.x.x 255.255.255.0
 ip helper-address x.x.x.x
interface Vlan2
 description Management
interface Vlan3
 description Data
interface Vlan4
 description Server VLAN
interface Vlan5
 description Printer VLAN
interface Vlan6
 description Voice VLAN
interface Vlan7
 description Video VLAN
interface Vlan8
 description iSCSI VLAN
interface Vlan9
 description BYOD
 ip pim dense-mode
interface Vlan10
 description Guest VLAN
interface Vlan11
 description IA_WIFI
interface Vlan12
interface Vlan14
 description Cluster
interface Vlan15
 description Live Migration
interface Vlan254
 description Internet Transit
 ip address x.x.x.x 255.255.255.248
router ospf 1
 redistribute static subnets route-map STATIC-TO-OSPF-MAP
 network x.x.x.x
 network x.x.x.x
 network x.x.x.x
 network x.x.x.x
 default-information originate metric 1
no ip http server
ip http authentication aaa
ip http secure-server
ip route 0.0.0.0 0.0.0.0 x.x.x.x
ip access-list standard STATIC-TO-OSPF
 permit x.x.x.x
 permit x.x.x.x
 permit x.x.x.x
 permit x.x.x.x
ip radius source-interface Vlan2
logging trap warnings
logging source-interface Vlan2
logging host x.x.x.x
arp x.x.x.x 0100.5e71.0446 ARPA
arp  x.x.x.x 03bf.0a02.04a9 ARPA
route-map STATIC-TO-OSPF-MAP permit 10
 match ip address STATIC-TO-OSPF
ntp server nist-time-server.eoni.com
wsma agent exec
 profile httplistener
 profile httpslistener
wsma agent config
wsma agent filesys
wsma agent notify
wsma profile listener httplistener
 transport http
wsma profile listener httpslistener
 transport https
ap group default-group
end
User Stack
This is the user stack which is only does layer 2 functions
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime show-timezone
hostname xxxxx
boot-start-marker
boot-end-marker
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
logging console emergencies
aaa new-model
aaa authentication login default group radius local
aaa authorization exec default group radius local
switch 1 provision ws-c3850-48p
switch 2 provision ws-c3850-48p
ip routing
ip device tracking
crypto pki trustpoint TP-self-signed-723753763
 subject-name cn=IOS-Self-Signed-Certificate-723753763
 revocation-check nonexxxxx
crypto pki certificate chain TP-self-signed-723753763
 certificate self-signed 01
 xxxxx
        quit
diagnostic bootup level minimal
identity policy webauth-global-inactive
 inactivity-timer 3600
spanning-tree vlan 1-4094 priority 16384
redundancy
 mode sso
lldp run
interface Loopback0
 ip address 10.x.x.x 255.255.255.0
 ip mtu 1500
Interfaces removed
 description Uplink to SFN-SW3
interface GigabitEthernet0/0
 vrf forwarding Mgmt-vrf
 no ip address
 negotiation auto
 description Reception 1
 switchport access vlan 3
 spanning-tree portfast
interface Vlan1
 no ip address
interface Vlan2
interface Vlan11
 no ip address
interface Vlan12
 no ip address
ip default-gateway 10.x.x.x
no ip http server
ip http authentication local
ip route 0.0.0.0 0.0.0.0 10.x.x.x
logging host 10.x.x.x
 length 0
ntp server 10.x.x.x version 2
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
 transport http
 transport https
end
sfn-sw2#
Something to note:
Another thing that has been happening which I thought was unrelated was that our management interfaces on our UCS environment have been crashing.  While looking through some logs I found a new server build that did not have any static or DHCP addresses assigned came up with a duplicate IP with our UCS management IP.  Very strange.
Thanks for looking at this.
