What are tunnels
blue4cisco
What r tunnel through WAN . any guidence or tutorials on tunnels function in a company's network ?
spremkumar
Level 9
Level 9
hi
This link contains insight view on the types of tunnels available now ..
http://www.cisco.com/en/US/tech/tk827/tk369/tsd_technology_support_protocol_home.html
regfds
devang_etcom
Level 7
Level 7
hi,,,
you can say tunnel is like virtual link...and it will hide your physical interface ip address...u can provide the authenticaion also at both end as well as u can establish the secure connection on it...
regards
Devang
So, What's diffrence betwen VPN Network & tunnel network ?
a vpn network is setup specifically to allow connectivity to resources on a private network while requiring the security & authentication.
a tunnel on a network could be setup to simply allow the finance department send secured data to the marketinng department.
a tunnel on a network can also allow for a certain protocol to be tunneled through the network that could not otherwise be sent on its own due to limitations in the network.
