What happens when a c9300 goes from EVAL MODE to EVAL MODE Expired
I currently only need network essentials   I am using IOS Fuji 16.9.3 on C9300 switches in my home.
Thx
Bryan
Reza Sharifi
Hi Bryan,
When the EVAL expires, nothing will happen unless you reboot. If you reboot, the license will not be activated.
Restrictions for Configuring RTU Licenses
The following are the restrictions for configuring and using RTU licenses.
IOS Fuji versions after 16.9.1 do not support RTU.  I am asking about  16.9.3.
Thx
Bryan
That is just a command that has been deprecated it.  I don't think that changes how the license function.
Starting from Cisco IOS XE Fuji 16.9.1, the Right-To-Use (RTU) licensing mode is deprecated, and the associated license right-to-usecommand is no longer available on the CLI.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/16-11/release_notes/ol-16-11-9300.html
Hello..
I have bought 2 C9300 with an essential license not connected to a smart account yet, I changed the boot level to advantage to configuring the VRF so what is happen after 90day ??? and It is mandatory to connect the device to a smart account to enable the license ???
