IP Source Guard Issues
jlimbo987
Visitor
Hi All,
I'm trying to get source guard working. I've configured DHCP Snooping and DAI and they are working fine. I've tried to configure IPSG with just IP and also IP and MAC verification. When I'm just using IP verification the pings from host to gateway timeout, when I add MAC verification they change to unreachable. The following config is on the access ports:-
interface GigabitEthernet0/2
switchport access vlan 10
switchport mode access
switchport port-security
ip arp inspection limit rate 10
negotiation auto
ip verify source port-security
ip dhcp snooping limit rate 20
end
The results of show ip verify source:-
S#sh ip verify source
Interface Filter-type Filter-mode IP-address Mac-address Vlan
Gi0/2 ip-mac active 10.0.10.7 00:50:79:66:68:00 10
Gi0/3 ip-mac active 10.0.20.6 00:50:79:66:68:01 20
Gi1/0 ip-mac active 10.0.30.6 00:50:79:66:68:02 30
Gi1/1 ip-mac active 10.0.50.6 00:50:79:66:68:03 50
Gi1/2 ip-mac active 10.0.51.6 00:50:79:66:68:04 51
Gi1/3 ip-mac active 10.0.52.6 00:50:79:66:68:05 52
The results of show ip dhcp snoop binding :-
S#sh ip dhcp snoop bin
MacAddress IpAddress Lease(sec) Type VLAN Interface
00:50:79:66:68:02 10.0.30.6 56576 dhcp-snooping 30 GigabitEthernet1/0
00:50:79:66:68:04 10.0.51.6 77275 dhcp-snooping 51 GigabitEthernet1/2
00:50:79:66:68:03 10.0.50.6 78272 dhcp-snooping 50 GigabitEthernet1/1
00:50:79:66:68:05 10.0.52.6 79735 dhcp-snooping 52 GigabitEthernet1/3
00:50:79:66:68:01 10.0.20.6 77224 dhcp-snooping 20 GigabitEthernet0/3
00:50:79:66:68:00 10.0.10.7 78129 dhcp-snooping 10 GigabitEthernet0/2
Total number of bindings: 6
From what I understand, this all looks right, however no traffic, including DHCP traffic, is allowed and the debug output for ip verify source packets shows this :-
*Dec 16 15:16:34.342: DHCP_SECURITY_SW: receive port security packet, recv port: GigabitEthernet1/0, recv vlan: 30, consume flag: 0, handle flag: 1.
*Dec 16 15:16:34.343: DHCP_SECURITY_SW: validate port security packet, recv port: GigabitEthernet1/0, recv vlan: 30, mac: 0050.7966.6802, invalid flag: 0.
*Dec 16 15:16:34.343: DHCP_SECURITY_SW: receive port security packet, recv port: GigabitEthernet1/0, recv vlan: 30, consume flag: 1, handle flag: 0.
*Dec 16 15:16:35.332: DHCP_SECURITY_SW: receive port security packet, recv port: GigabitEthernet1/0, recv vlan: 30, consume flag: 0, handle flag: 1.
If anyone one has any pointers on how to fix this it would be greatly appreciated
23 Replies 23
Hello
What platform of switch and software image are you using?
sh version
Kind Regards
Paul
Hi Paul,
For now I'm testing this on IOSvL2 with 15.2.1 image, but this is going to be deployed on a range of kit including 2960s and 9200s
John
Hello
Just to confirm you haven't applied IPSG to any uplinks - Correct?
Kind Regards
Paul
Hi Paul,
No, it's only on access ports
Hello
I wonder if this is a trait in the vm software, I have a CML  Possibly I could test it also.
can you run a debug and see what results you get.
no ip dhcp snooping information option
debug ip dhcp detail
Kind Regards
Paul
The dhcp won't work with no ip dhcp snooping information option set. Also, no option of debug ip dhcp detail
debug ip dhcp ?
server          DHCP server activity
snooping     DHCP Snooping
S#debug ip dhcp server ?
binding-store     Binding data store
class                  Class-based address allocation
events                Report address assignments, lease expirations, etc.
linkage               Show database linkage
packet                Decode message receptions and transmissions
redundancy        DHCP server redundancy events
snmp                 DHCP server snmp events
S#debug ip dhcp snoop ?
H.H.H                 DHCP packet MAC address
agent                 DHCP Snooping agent
event                 DHCP Snooping event
packet               DHCP Snooping packet
show port-security for GE0/1,
can you share it?
Port security isn't configured on g0/1, that's an upstream trunk port
S#sh port-sec int g0/1
Port Security : Disabled
Port Status : Secure-down
Violation Mode : Shutdown
Aging Time : 0 mins
Aging Type : Absolute
SecureStatic Address Aging : Disabled
Maximum MAC Addresses : 1
Total MAC Addresses : 0
Configured MAC Addresses : 0
Sticky MAC Addresses : 0
Last Source Address:Vlan : 0000.0000.0000:0
Security Violation Count : 0
sorry, if it upstream which lead to DHCP server so by the DHCP snooping enable on it?
Yes, so its a trusted port for DHCP Snooping and DAI
interface GigabitEthernet0/1
 switchport mode trunk
 ip arp inspection trust
 negotiation auto
 ip dhcp snooping trust
end
dhcp snooping database entry show MAC address and IP address on Ge0/1 which lead to Server,
the entry is add only If the SW DHCP ACK for ip address request from this port.
what is more detail about this IP address.
The database doesn't have an entry for G0/1. I has an entries for g0/2, g0/3, g1/0, g1/1, g1/2 and g1/3
Hello
Just an update on this, I tested this in CML and it does seem to suggest IPSG is a bit flaky running on this vm code, DHCP snooping/DAI work okay although with DHCP snooping/DAI and IPSG I was able still able obtain dhcp allocation without any problem
However I noticed even having identical dynamic entries into the snooping/source binding tables I wasn’t able to ping anything which i wouldnt expect unless I those host mac/ip addresses changed and didnt reflect the entites of both tables, which seems wrong but if I statically entered the same binding entry manually and enabled device tracking on the access port (as you would for static address assignment), I was able successfully reach other devices, locally or remotely, sggesting the by default in this lab both snooping/source tables were not being read successfully by the switches and only bypassing them with static enties worked.
sh ver | in Soft
Cisco IOS Software, vios_l2 Software (vios_l2-ADVENTERPRISEK9-M), Version 15.2(CML_NIGHTLY_20190423)FLO_DSGS7, EARLY DEPLOYMENT DEVELOPMENT BUILD, synced to  V152_6_0_81_E
ip dhcp snooping vlan 1,10,20,30
ip dhcp snooping
ip arp inspection vlan 1,10,20,30
interface GigabitEthernet0/0
spanning-tree portfast edge
sh ip source binding
52:54:00:17:7D:22   192.168.10.2     5186    static          10    GigabitEthernet0/0
sh ip verify source
Gi0/0      ip-mac       active       192.168.10.2     52:54:00:17:7D:22  10    < --------icmp doesn’t work
However changing to a static IPSG entry I obtain reachability
ip device tracking maximum 5
ip verify source tracking port-security
ip source binding 5254.0017.7D22 vlan 10 192.168.10.2 interface Gi0/0
sh ip source bi
52:54:00:17:7D:22 192.168.10.2 infinite static 10 GigabitEthernet0/0
sh ip ver source
Gi0/0      ip-mac trk   active       192.168.10.2     52:54:00:17:7D:22  10
Kind Regards
Paul
Thanks Paul,
I've got some live kit I can try it out on next week, so I'll try the same config on that and see what happens
John
