What if switch "switchport mode access" not assigned to switch port
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
06-24-2008 04:16 PM - edited 03-05-2019 11:48 PM
I came across a prod environment where the 3560 switch connecting to end hosts do not have 'switchport mode access' command. switchport access vlan 15 is existing but not the other command...
So it looks like this..
interface FastEthernet0/10
description :User1 PC
spanning-tree portfast
PCc working. So when the command is not issued and/or issued what will be the difference.
Thank you
MS
- Labels:
Other Switching
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-24-2008 04:44 PM
Defining the switchport itself with access vlan statement will have the port in access mode.
The difference will appear only if neither access vlan nor access mode is defined.
Pls rate/mark if this helps!!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-24-2008 06:37 PM
without 'switchport mode access', the switchport is a candidate to become a trunking port, if it detects another potential trunking device plugged into this port.
with 'switchport mode access' enabled, you disable trunking altogether. you can take this one step further by adding 'switchport nonegotiate'.
