What is Backplane and switch fabric?
Hi...
I am finding it very difficult to understand the terms backplane and switch fabric.
Are they same or different.And how to find the backplane speed etc
Kindly explain.
Regards.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Sometimes used for the same thing, sometimes not.
Generally a fabric would be something mentioned with switches as it provides a paths between ports that are not shared.  If you had ports A,B,C and D.  A and C could "converse" while B and D also "converse", but without any bandwidth contention.
Generally a backplane is the what you plug cards into and is part of the "empty" chassis; it may have a fabric architecture or a bus architecture (or some combination).
