CCIE Kit
rahman001
Level 5
Level 5
Dear Sir,
Please we are trying to create a small CCIE lab(RnS) in our DEMO center.
We are looking on getting like  3 units of routers and  3 units of layer 3 switches.
I hope this qty will be enough?
Can you help me come up and generate a BoM for this( maybe a mix of 2900 series router and 3750 switches)
Br
Samson
manish arora
Level 11
Level 11
No they are not going to sufficient with the release of Version 5 for CCIE R&S, as per Cisco the topologies in the exam are going to large & they will be using IOU (virtual devices) for the exam now. You are better of downloading the IOU web instances from Internet & also see how you can create both Routing & most of the switches labs on it.
Manish
