what is difference between AUSR and DUSR ?
ganeshkacn143
What does AUSR in switch name idicates
5 Replies 5
I need to see the exact name
SW-FRPAU-X00I1B-AUSR#
this Host name, it user configurable it not cisco default name.
check the
hostname command in running/startup config
ganeshkacn143
SW-FRPAU-X00I1B-AUSR#    What does AUSR in switch name indicates
You need to check with your local naming convention part of your design, this is not come with cisco or any one.
this is easy to identify the device and role.
i believe this is AUS- australi - R - Router ( guess)
BB
