what is different between N3K-C3064PQ-10GX vs N3K-C3064PQ-10GE?
gordonsung777
as per the cisco documents, in GX model, device defined as a 'low latency'. use below links for more details. both models are EOS.
https://www.cisco.com/c/en/us/products/collateral/switches/nexus-3000-series-switches/eos-eol-notice-c51-736391.html
https://www.cisco.com/c/en/us/products/collateral/switches/nexus-3000-series-switches/eos-eol-notice-c51-738099.html
datasheet,
https://www.cisco.com/c/en/us/products/collateral/switches/nexus-3000-series-switches/data_sheet_c78-651097.html
please rate if helps
regards,
Good luck
KB
The main difference between the N3K-C3064PQ-10GX and the N3K-C3064PQ-10GE lies in the specifications of their interfaces:
  • N3K-C3064PQ-10GX: The "GX" suffix generally refers to interfaces that support 10 Gigabit Ethernet transceivers with high-speed and low-latency standards. This model is specifically designed to offer 10 Gbps connectivity with high efficiency in demanding network environments.
  • N3K-C3064PQ-10GE: The "GE" suffix refers to standard 10 Gigabit Ethernet interfaces. While it also provides 10 Gbps connectivity, this model may be more focused on solutions that do not necessarily require the same advanced latency or flexibility features as the "GX" model.
In summary:
  • "GX" may have better optimization for low latency or more demanding conditions.
  • "GE" is a common standard for 10 Gigabit Ethernet, without an emphasis on advanced features like ultra-low latency.
