01-06-2023 01:47 PM
When we ping to any server then we see pattern drop so why did we see like this?
how to identify pattern drop?
is it settings that is done?
01-06-2023 02:40 PM
It all depend on what desitnation IP you pinging and where that is located
can you post the example output?
=====️ Preenayamo Vasudevam ️=====
01-07-2023 03:44 AM
#ping x.x.x.x repeat 100
Sending 100, 100-byte ICMP Echos to , timeout is 2 seconds:
Success rate is 76 percent (76/100), round-trip min/avg/max = 1/2/12 ms
#ping x.x.x.x repeat 1000
Sending 1000, 100-byte ICMP Echos to , timeout is 2 seconds:
Success rate is 76 percent (766/1000), round-trip min/avg/max = 1/1/12 ms
01-07-2023 06:46 AM
ok we know the pattern drops, this several causes around the network to find out the correct what is wrong - you need to troubleshoot in different gateway or next hops.
what is the device IP source you pinging ?
what is the destination IP x.x.x.x ? (if this is public IP you no need to provide but give that information)
is this destination inside your network ? how many hops from the source IP ?
from the source, IP are you able to ping the gateway the same way? what was the outcome?
Do you have any small network diagram which shows the source device and destination device?
Good to have information is what is the device, and what IOS code running. do you have a routing protocol running or a static route ?
01-06-2023 03:05 PM
any server or cisco device have a technique to protect from DDoS,
but I ping not DDoS to Server?
it same for Server, if server or cisco device see multi high rate ping it assume it DDoS not usually ping and hence drop some to protect it.
01-07-2023 03:42 AM - edited 01-07-2023 03:43 AM
Please find---
01-07-2023 05:00 AM
first do tracreroute see if the hop appear is same for three probe,
can you share output?
01-07-2023 09:19 AM
"When we ping to any server then we see pattern drop so why did we see like this?"
There are multiple possible reasons, not all exclusive with each other.
Some of the more common reasons include:
Host "thinks" it might be being "attacked" with successive ping requests, so it throttles responses. (As mentioned by @MHM Cisco World.)
Host is particularly "busy" and doesn't want to waste its resources on replying to every ping request. (Same reason might also cause highly variable ping response times. I.e. host delays its response to when it's not as busy.) (Sort of also like WC Field's "go away kid, you bother me".)
Ping requests (or corresponding ping responses) are dropped, in transit, due to congestion somewhere along one or both (i.e. to and/or from) paths.
BTW, ping, fundamentally, is really to allow one host to determine if another host is "alive". So, not responding to every ping request, from the same host, is fine for that purpose.
