what is routed port and meaning of that
knaik99
Giuseppe Larosa
Hello @knaik99 ,
on a multilayer switch you have the option to configure a physical port as a routed port like in a router the port will act as a L3 interface
example:
int gi1/0/25
no switchport
ip address 10.10.25.1 255.255.255.0
no shut
Actually, the implementation uses an internal VLAN for this an high value like 3785 creates an SVI with that IP address and associates the physical port to that VLAN in addition all L2 protocols like STP, DTP VTP are disabled / filtered. CDP or LLDP MED are still enabled.
A switched port is a port that acts as an access port or a trunk port as a stand alone or as member of a port channel.
Hope to help
Giuseppe
balaji.bandi
Router port - In general switch point of view, by default all the ports in Switch are layer 2, if you issue command "no switchport"
that become layer 2 switch port to routed port ( assing a IP address) become layer 3 port.
make sense ?
BB
Joseph W. Doherty
Giuseppe's post has all the particulars, but it's also a configuration "shortcut" to configure an access port like, and its functionally, like a router's port.  I.e. you can achieve the same result, if you properly configure the access port, but just using "no switchport" is much simpler, and better "documented" (as to how the port is being used).
As an aside, this is sort of the same idea, i.e. a configuration "shortcut", that's also used when you configure an access port with a voice VLAN (which really makes the port a "restricted" trunk port).
