what is the best practice on wlan
dsolangon
If have multiple access points manage by a controller what is the best port configuration on the access switches going ti the access points? Example spanning tree etc..
6 Replies 6
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Port-channel.
PS:
After reading Leo's post, realize I misread your question.  As there's only one (?) connection to the LWAP, you can treat the port as an access port.
One thing you might do, on the controller, activate MSS adjustment for the LWAP tunnel.
Leo Laohoo
If your WAP has FastEthernet, connect the WAP to a FastEthernet port.  If the WAP has GigabitEthernet, connect to a GigabitEthernet port.
There's madness as to the reason why it's got GigabitEthernet interface and it's got NOTHING to do with bringing the cost down.
How can i prevent mac flapping on the accesspoints? Example i have my ipad connected to the wlan and moving across the floors.
Do you actually see errors of "MAC Flapping" in the logs?  Because I have never seen an iPad "MAC Flap".
Sorry example is my laptop connected to the wifi
Jeff Van Houten
Level 5
Level 5
As Joseph pointed out it should be an access port, and hopefully it is in a vlan that is NOT associated with any of the subnets advertised by the wlc. You can also enable port fast to transition the port quickly on a switch reboot. You can put bpduguard on as well.
