What is the difference between Catalyst 9300, 9300X, 9300L, 9300LM?
I don't understand differences between Catalyst 9300, 9300X, 9300L, 9300LM. And also I don't understand the meaning of those extension. Someone please help me to understand those.
C9300X-48HX -> HX
C9300X-48TX -> TX
C9300X-48HXN -> HX
C9300X-12Y -> Y
C9300-24UX -> UX
C9300-48UXM -> UXM
C9300-48UN -> UN
C9300-24UB -> UB
C9300-24UXB -> UXB
C9300-48H -> H
C9300-24S -> S
C9300L-48UXG-4X ->UXG
3 Accepted Solutions
marce1000
 - Ref : https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/nb-06-cat9300-ser-data-sheet-cte-en.html
                                Have a look at Table 2.
 M.
Blue_Bird
Hello Md. Shahariar Rahaman ,
Those are the Model Numbers....of Catalyst 9300 series switches...
One of the primary benefits of the 9300LM(mini) is the shallow depth form factor (12-13.2 inches depending on power supply) vs. 9300L (19.2 inches)
Reference: https://community.cisco.com/t5/switching/catalyst-9300l-vs-9300lm/td-p/4635597
Best regards
******* If This Helps, Please Rate *******
Hello Md. Shahariar Rahaman,
  • The Cisco Catalyst 9300 Series switches are the next generation of enterprise-class stackable fixed access-layer switches. They provide the highest density of 10G multigigabit and 90W UPOE+ per port and 100G uplinks.
  • Recently Cisco has added to that family with the C9300X. The C9300X is a high-performance access switch with support for 48 mGig-10G interfaces, 90W UPOE+, as well support for 100G uplinks using a network module (NM).
  • With double the local compute for app hosting, the Catalyst 9300X models can serve many different needs for hybrid work, smart buildings, and can even be a “branch in a box” solution for lean branch sites not using SD-WAN.
Best regards
7 Replies 7
marce1000
 M.
Your mirror is broken my friend
Blue_Bird
Best regards
Thanks for your valuable replay. Can you give me the difference between C9300 and C9300X ?
Best regards
the C9300, C9300X and C9300L have different hardware architecture
Cisco Catalyst 9300 Series Switches Architecture White Paper - Cisco
look at the figures in section: Chassis design
mickrame
A little late but this may help.
