What is the max number of 3850 switches in a stack
rsalahuddin
Hi Christopher - Cisco switches allow you to stack a total of 9 switches. To my best knowledge, this rule applied to any stack-able Cisco Catalyst switch.
Rez
Thanks.. did a little more digging.
Its up to 9 now.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/3se/release_notes/OL_30562_01.html
Rajeev Sharma
Hey,
Currently 4 units are supported however 9 will be supported in future releases. FYI:
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3850-series-switches/qa_c67-722110.html
HTH.
RS
bobbyh
Up to 9 Cisco Catalyst 3850 switches can be stacked together to build single logical StackWise-480 switch since Cisco IOS XE Release 3.3.0SE.
Prior to Cisco IOS XE Release3.3.0SE, up to 4 Cisco Catalyst 3850 switches could be stacked together.
