What is the maximum concurrent SSL/VPN connection on Cisco1941-SEC/K9?
reycapoy
  Good Afternoon.  I would like to ask if what is the maximum concurrent that a CISCO1941-SEC/K9 could handle.  The scenario is that on a lending company running SQL 2008 R2 and other applications, 50 to 100 branches using RV042G will connect to the main office to access the database.  Can the CISCO1941-SEC/K9 be able to handle this?  As of now the existing internet connection is running at 2Mbps at the main office and at their branches.
johnlloyd_13
Level 9
Level 9
You issue 'show webvpn license' to find it out.
