What is the meaning of E, L and F in C1000 series switches?
I've noticed that most C1000 switch models end with "L". However, I'm unsure what the "L" signifies. Additionally, some switch models also include "E" or "F", and I'm curious about their meaning as well. Could you please explain what these letters indicate?
And also I need to know difference between C1000 and C1000FE.
2 Accepted Solutions
I'm pretty sure the L = LAN Base.  I think E = IP Services and not sure about F.
Richard W. Pidcock
pieterh
the -FE models will be FastEthernet
instead of 10/100/1000 interfaces these only have 10/100 interfaces
see rightmost models in Catalyst 1000 Series Switches - Cisco
and of course the datasheet: Cisco Catalyst 1000 Series Switches Data Sheet - Cisco
Table 1
Product ID*
Gigabit Ethernet / FE ports
Uplink interfaces
PoE+power budget
Fanless
Dimensions (WxDxH in inches)
Weight (kg)
C1000FE-24T-4G-L
24 10/100 RJ45 Data
2 SFP/ RJ-45 combo and 2 SFP
Y
17.32 x 11.34 x 1.73
3.56
C1000FE-24P-4G-L
24 10/100 RJ45 PoE+
195W
Y
17.48 x 13.78 x 1.73
4.52
C1000FE-48T-4G-L
48 10/100 RJ45 Data
N
3.97
C1000FE-48P-4G-L
48 10/100 RJ45 PoE+
370W
N
5.46
I already checked this. But after that I can't understand something. That's the reason i did this post. If you explain this please do this. It will be helpful for me. Thank you for your reply.
Richard W. Pidcock
pieterh
Table 1
Product ID*
Uplink interfaces
PoE+power budget
Fanless
Weight (kg)
C1000FE-24T-4G-L
24 10/100 RJ45 Data
Y
3.56
C1000FE-24P-4G-L
24 10/100 RJ45 PoE+
195W
Y
4.52
C1000FE-48T-4G-L
48 10/100 RJ45 Data
N
3.97
C1000FE-48P-4G-L
48 10/100 RJ45 PoE+
370W
N
5.46
