what is the use of no switch port command in L3 switch?
vinothlb1
7 Replies 7
Collin Clark
It makes the port into a routed port and you can apply an IP address directly to the port.
Hope that helps.
Can u give any example scenario.
You use it as any routed port such as on a router. Instead of using a SVI and putting a port into that vlan you put the addressing info (gateway) directly on the port interface versus the SVI. You can then just connect to any other network device like a switch for layer 3 routing in that subnet.
Could you provide an example of the commands one would use to configure switchport to be a routed port. Please include how you would 'put the addressing info (gateway) directly on the port'.
TIA
This is for a 3750
interface GigabitEthernet1/0/1
description example router port1
no switchport
ip address 10.10.10.1 255.255.255.0
no ip redirects
interface GigabitEthernet1/0/2
description example router port 2
no switchport
ip address 10.10.11.1 255.255.255.0
no ip redirects
For default gateway you can use either
ip route 0.0.0.0 0.0.0.0 "ip of default gateway"
or
ip default-gateway "ip of default gateway"
do not forget to enable the ip routing in the switch.
Could any one please advise the following :  I almost have same issues as above.
I have 2 router connected to a 3750. Router A is hooked up with Internet and Router B is also hooked up with Internet
Current all the Traffic is going to Router A, I have connected the Router B on the 3750 and configured as no switch port and given a IP.
I was woundering how can I determine or change some traffice to go to Router B as all are going to Router A.
Below is the configuration that I have :
ip   default-gateway 192.168.100.1
ip http server
ip http secure-server
ip route 0.0.0.0 0.0.0.0   192.168.100.1
ip sla enable reaction-alerts
access-list 20 permit 0.0.0.0   255.255.255.0
access-list 40 permit 0.0.0.0   255.255.255.0
access-list 100 remark GUEST   NETWORK CONTROL
access-list 100 permit udp   172.20.20.0 0.0.0.255 host 192.168.171.1 eq domain
access-list 100 permit udp   172.20.20.0 0.0.0.255 host 192.168.171.30 eq domain
access-list 100 permit udp any   any eq bootps
access-list 100 permit udp any   any eq bootpc
access-list 100 deny   ip 172.20.20.0 0.0.0.255 192.168.168.0   0.0.3.255 log
access-list 100 deny   ip 172.20.20.0 0.0.0.255 192.168.10.0   0.0.0.255 log
access-list 100 deny   ip 172.20.20.0 0.0.0.255 192.168.20.0   0.0.0.255 log
access-list 100 deny   ip 172.20.20.0 0.0.0.255 192.168.30.0   0.0.0.255 log
access-list 100 deny   ip 172.20.20.0 0.0.0.255 192.168.40.0   0.0.0.255 log
access-list 100 deny   ip 172.20.20.0 0.0.0.255 192.168.50.0   0.0.0.255 log
access-list 100 deny   ip 172.20.20.0 0.0.0.255 192.168.60.0   0.0.0.255 log
access-list 100 deny   ip 172.20.20.0 0.0.0.255 192.168.70.0   0.0.0.255 log
access-list 100 deny   ip 172.20.20.0 0.0.0.255 192.168.90.0   0.0.0.255 log
access-list 100 deny   ip 172.20.20.0 0.0.0.255 172.20.10.0   0.0.0.255 log
access-list 100 deny   ip 172.20.20.0 0.0.0.255 172.20.30.0   0.0.0.255 log
access-list 100 deny   ip 172.20.20.0 0.0.0.255 172.20.40.0   0.0.0.255 log
access-list 100 permit ip   172.20.20.0 0.0.0.255 any
it alll depends on you setup and the  feature sets.
When you have independent internet lines you can not simple loadbalance on the 3750.
You may whant to have a look into policy based routing wiht this you can assign protocols or hosts to a specific line.
